Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Poulan Pro mower starter engages but plugs don't have any fire.
Are there any points and condeser in this model, if so where are they.
  • 376 Answers
No points and condenser. Brigg and Stratton hasn't had points and condensers since 1981. Dwain
Posted on May 24, 2009
What is wrong with poulan pro riding mower
You need fuel, fire, and compression. Also look for a push rod off its rocker if it is OHV.
Sep 06, 2014 | Cars & Trucks
Poulan pro engine dies when blades are engaged
Something may be wrapped around the blade shaft under the mower deck or maybe the shaft bearings are bad.
Aug 10, 2014 | Poulan Garden
Why does my Poulan 625 lawn mower when using the key start makes a whirring sound and not start?
maybe this might help, some of the newer engines have an oil alert. if the oil level is low it won't start.
Aug 01, 2014 | Poulan Pro 22" Self Propelled High Wheel...
Poulan pro 625 lawn mower idles slow and rough
Try changing your plug and check gap and put in some fresh fuel. Empty out the old stuff especially if it has been there a while. Also check your low idle setting on the carb open it up a half turn for starters. Good Luck...
Aug 27, 2011 | Poulan Pro 22inch 625 Series Briggs ...
My 54" Poulan Pro riding mower dies when the
battery weak replace or charge, mower has electric clutch which pulls amps from battery
Jun 26, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Poulan pro lawn mower starts & dies
unless this mower is older then i am, it has no points or condenser. It has only a magnito. Sounds more like a plugged up carberator.
Apr 30, 2010 | Garden
It won't keep going.
Remove and clean out the carburettor, its dirty and full of old dead fuel.
Apr 25, 2010 | Poulan "Poulan" Push Mower
Where are the oil drain plugs for a poulan pro 550 model
under the deck above the blade. It is probably a square head pipe plug
Oct 17, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Mar 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
69 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
