Question about Miele CVA4070 Coffee Maker
Miele CVA 4075 Coffee maker stuck in cleaning phase
My Miele CVA 4075 will not finish cleaning. It stopped at 1 minute and no water came out and now when I turn it back on it just says cleaning . Any suggestions
4 Suggested Answers
SpotBert
  • 231 Answers
SOURCE: miele CVA 4070 coffee system
I called Miele hot line & here is the solution to fixed the problem... 800-999-1360.
http://www.miele.com/
Whenyou start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
Posted on Jan 03, 2009
SOURCE: Miele Coffee maker cva 615
The screens that the coffee grinds are squeezed in between are clogged. You need to remove the brew unit, remove the bottom screen, (should be one phillips screw in the center) and scrub the screens clean. You need to clean all of the really fine holes out so that the water can pass through. To prevent this in the future, use the rinse cycle on the machine frequently and also take the brew unit out and rinse it under hot water everytime you dump your waste unit.
Posted on Oct 20, 2008
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
Miele CVA5065 coffee machine- the manual states : "fill the big plastic container to the max level". What is the volume to the max level?
Filling The Water And Coffee Bean Containers - Miele CVA ...
www.manualslib.com > ... > Coffee Maker > PW 5065 > User manual
Miele CVA 5065 Manual Online: Filling The Water And Coffee Bean Containers. Thecoffee machine must be cleaned thoroughly (see ''Cleaning and care'') before you... ...up to the "Max." mark. A valve at the front of the water. container will ...
[PDF]Operating and installation instructions Built-in coffee ...
Nov 25, 2015 | Miele Coffee Makers & Espresso Machines
Miele cva 4075 stuck brewing unit
http://mielerepaircenter.com/miele-coffee-maker-repair
Sep 07, 2014 | Miele CVA4070 Coffee Maker
The coffee dispenser leaks out in other places
I've got the same problem on my CVA 4075... Coffee comes out all around the dispenser not so much through the tubes. How do I get this part out to clean it?
Mar 17, 2014 | Miele CVA4070 Coffee Maker
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
My miele cva 4075 is not heating the frothed milk or coffee up as well any more...sometimes a Fault 73 shows on the screen..i have cleaned the brew unit with tablets and water etc...what should i do next?
Hello Loriktarrant,
I understand the your Meile CVA4075 is showing you an F73 code. This code means that the brew unit needs to be cleaned. Here is a link to the owners manual on page 40 it shows you how to manually remove and clean the brew unit. The other issue you are having with the milk and coffe not being hot enough could be to the machine needing descaled.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man enter the numbers in the box and click download.
Thank you for choosing FixYa.com
Justin
Mar 12, 2011 | Miele Coffee System
Apr 13, 2010 | Miele CVA4070 Coffee Maker
Machine locke in cleaning phase, how to release?
When the machine is in the cleaning phase you must let it stop on its own. Don't add water. If it is descaling it must complete 2 cycles. The descaling cycle and the rinsing cycle. If its doing a brew cleaning it has to finish the the 1 cycle. It will tell you what to do in the menu. Walk away and let it finish.
Dec 18, 2009 | Miele CVA4070 Coffee Maker
How do i clean my miele coffee system cva 4070?
I have a cva4075 so this may not be exactly the same, but on the 4075 you open the front of the machine and pull out the left hand plastic container on the top. Underneath on the right hand side you will see a small flap. On the bottom side of the flap is a red triangle sign. That flap is the top of the funnel for the ground coffee. You drop the cleaning tablet into this funnel.
Apr 12, 2009 | Miele Coffee Makers & Espresso Machines
Miele CVA- 4075
You need a new Elektronik. The one in the back of the Coffee maschine has to be changed. There is a technical Problem in the Clock Module.
Greeteings ....
Mr. Cool
Dec 02, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Miele CVA 4070 coffee system
Aug 25, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4070 Coffee Maker Logo
1,438 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
