Question about Car Audio & Video
Need to find the antenna connection into the factory radio on 99 chevy suburban
I nee to remove my factory radio in my 99 chevy suburban so i can get to the antenna becaus i'm adding XM and i have a direct connect for the XM that connect in to the antenna
  • 87 Answers
Pull the dash bezel off, lower the sterring wheel, apply parking brake, lower gear shift to 1st - apply gentle pressure and MAKE SURE there are no screws by cup holder. You will see the stereo and how it is mounted. That either has small bolts 5/16 or 2 snap clips that you depress and pull forward. Just be gentle but firm and you will be fine. You will also need 2 antenna adaptors, just call any stereo shop and they can help you with that.
Posted on Jun 02, 2009
2000 chevy venture. How do I install a JVC stereo?
Check your local Walmart or Auto Parts store for the correct wiring kit to change your factory radio to a JVC...the kit is inexpensive and provides professional connections that are easy to trace...remove the face plate around your factory radio, and you will see 4 corner bolts that hold the radio in place...be sure the antennae connections are the same size. Hope this helps.
May 15, 2015 | Chevrolet Cars & Trucks
How do you take out the factory radio in a 1992 Chevy suburban? trying to put in a new one, but taking out the old one is a HUGE issue!
No it's not. On the faceplate of the radio, there are 2-screws at the top of the plate. remove the screws and plate will comeout. You will see 2-nuts/bolts either on the side or at the top. Take them out. Pull radio back towards the seat to unveil the antenna wire and the 3-pluggins on the back of the radio. The antenna cable will pull out hard but pull it out, The blue, white and black plug-ins come out by pressing a flat tab on each one while pulling them out, Radio should slide out with ease,
Jan 23, 2013 | Cars & Trucks
Repair panel driver seat on1999 chevy suburban
Remove all screws, be sure to look carefully not to miss any. Usually in the armrest of the door, and up by mirror. Then using a plastic spatuala or equivilant carefully pry the plastic panel from the door a few inches at a time
Jul 23, 2012 | Metra 99-4544 1995-1999 Chevy C1500...
99 chevy suburban. rear speakers not working.
if you have a wiring guide for your deck, take a look at it and see what your rear speaker + and -'s are, connect them accordingly to the wiring guide in the link and your speakers should work, if not, the wires running to the speakers are probably damaged. if thats the case, go to a dollar store and pick up some speaker wire, and run it under your panels, or carpet, what ever is easier for the particular make.
Mar 17, 2010 | Panasonic Car Audio & Video
I have a 99 GMC suburban. I just replaced the AC
Find a blue wire on the wire harness to the truck and connect from the blue white on the radio. this will turn on the factory amp that runs the rear door speakers
Feb 08, 2010 | Car Audio & Video
How do you remove the trim around the factory
Unfortunately it has been a few years since I've removed the dash in my sisters 95 century(same setup as yours)... but I came across something that should give you some decent pointers.
http://www.pdfee.com/autos-how-to/99-4544-installation-instructions
that is a link to a pdf, which, on Page 3 gives a basic text description of what you need to remove in order to get the dash trim off and gain access to the radio. If that link does not work, here's the link the page from which you can download the above mentioned file also...
http://www.pdfee.com/99-4544-installation-instructions.html
Jan 09, 2010 | 1994 Buick Century
Hi! Need help in removing the front panels of 2009 nissan altima so I can install a radio. the car is basic, have all wiring and speakers, but no radio, i have the radio, harness and mounting kit, but I'm...
well to start you will nee an install mounting kit metra number 99-7423,
a wire harness 70-7552
and an antenna adaptor number 40-NI12
Now to remove the stereo you will need to pop off the trim ***. just below the heater control switches. the the vents above the radio. remove four phillips screws and then pull stereo/ heater assembly from dash.
Aug 27, 2009 | Car Audio & Video
Car Audio & Video Logo
141 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
