Question about Philips GOGEAR SA6045 MP3 Player
My philips mp3 gogear doesn't come on
When connected to the computer,it is recognised and it charges but when removed,it just goes off and does not come on.what should i do?.
    Problem Solver:
  • 6 Answers
Whenever this type of problem occurs in Hardware the best way and the right way is to change the battery. The battery of the GOGEAR may be damaged and may need replacing. I am sure that the problem will be solved when you change it.
(I AM SURE B'COZ I HAD THE SAME PROBLEM WITH MY GOGEAR OF 1GB MP4)
Posted on May 24, 2009
5 Suggested Answers
SOURCE: My computer doesn't recognise my gogear, how do i charge it?
Your computer must have, the service pack 2, if not, you can´t charge your reproducer.
Posted on Dec 12, 2008
bloodhound66
  • 55 Answers
SOURCE: Philips GoGear MP3 1GB player
if you dried it out in rice after the fall then you might have a problem with the mother board if it was on when you dropped the device into the water than you could have fried one of the servers that help your computer to recognize the device
hope this helps you
good luck
Posted on Jul 24, 2009
SOURCE: my computer will not recognise that my philips
xscdc
Posted on Apr 05, 2010
  • 161 Answers
SOURCE: my computer is not recognizing the philips Go Gear MP3 Player.
Hi go to the philips web site, download required software
Posted on Apr 17, 2010
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My Philips GoGear SA3125/02 (2GB) cannot be turned on unless I connect to the the computer. I therefore cannot listen to it without the computer. When it is turned on, it indicates Philips, and then GoGear...
Your Mp3 players battery is not charging. That is the reason its you are not able to use it without connecting to the computer. A replacement battery should resolve your problem.
Sai.
Oct 01, 2010 | Audio Players & Recorders
Ihave gogear sa32x wh i turn on on screen i see philips logo and
you may need to install the driver for the computer to recognise the mp3 player (go to control panel, swich to classic view if it isnt already and go to add hardware then follow the onscreen instuctions). 'ready to disconnect' is normal it is just telling you that it is safe to remove the player from the computer. 2 possibilities for turning off: the battery needs charging (connect to computer to do this) or the player is locked. refer to the user manual under controls to find out how to unlock it. as far as i know, as i have a gogear sa1922, there is a slider somewhere on the player to unlock it. hope this helps, solver214!
Oct 21, 2009 | Philips GoGear HDD6330 MP3 Player
Dec 12, 2008 | Philips GOGEAR SA6045 MP3 Player
Phillips gogear sa6185
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Oct 24, 2008 | Philips GoGear HDD075/17 MP3 Player
player says i should not connect and then that detachment is ok.
Oct 22, 2008 | Philips GOGEAR SA6045 MP3 Player
Phillips mp3 player
Connect the player to the power adaptor and connect to the PC.
On the player press and hold "Power" & "Vol +", this should reset the player.
Wait for PC to recognise player.
If this doesn't work try the following:
Connect the HDD6330 to the mains adaptor and the PC.
Before the computer has a chance to recognise the player, press "Power" and "Vol +" to reset the player.
As soon as the player resets (screen goes blank) press and hold "Vol -" until the PC recognises the player as a removable drive.
Try to access the player through "My Computer" as you would the main hard disk.
If the computer recognises the player, then it can be restored by copying the system files directly on to the player.
Feb 14, 2008 | Philips GoGear HDD6330 MP3 Player
Phillips GoGear not turning on
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Nov 29, 2007 | Philips GoGear HDD6330 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
421 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
