Question about Stainless Dishwashers
Door catching and will not open - Stainless Dishwashers
  • 3,361 Answers
If the door latch is releasing and the door is opening partially,
Remove the bottom"toe" plate. Look closely at the hinges and springs on the hinge glides. Something is binding there.
Posted on May 24, 2009
How do I change the door catch after I've reversed the door
Please see this video:
https://www.youtube.com/watch?v=b5JqWRMpuXU
Your goal is to switch the door catch to the opposite side of the door opening, and move the catch opening plate/cover to where the door catch was originally installed.
Apr 27, 2016 | Zanussi ZDC37100W Electric Dryer
How do I fix a sticking door catch?
Buy door latch lub for auto parts store.
May 26, 2014 | 2005 Renault Grand Scenic
The driver side door on my 2002 chevy blazer wont close.how do i fix it?
Door pins are a common failure on that series of Blazer/S10's. Also, another point of contention that the door faces is a sticky latch. Basically, the door latch re-latches itself and when you shut the door into the catch, it slams into it and bounces off. An easy fix is a 3 part cocktail of brake parts cleaner. Open and shut the latch with a screw driver acting as the catch and your interior door handle a few times. P'Blaster, open and shut the door a few times with the screwdriver acting as the catch. Finally, a good shot of white lithium grease. Open and shut the door with a screwdriver as the catch several times. Once you feel it is un-stuck, actually close and open the door several times. If you notice the door rising every time it catches, you MUST replace the door pins (cheap fix). If the door still has issues, replace the door latch (and since you're in there, do some PM and replace the actuator as well).
Apr 08, 2012 | 2002 Chevrolet Blazer
How to open the door of 773 model for replacing the damaged latch.? Hook like thing of the latch at the upper part is damaged and i have to replace it witha new latch. But I am not open the door.
To open the door, remove the appliance case and with a long small diameter screwdriver, gently lift the catch holder assembly up to release the door catches.
When you replace the door catch, ensure that the door fits correctly.
Oct 28, 2010 | Panasonic Microwave Ovens
Door handles slack feels like springs dropped so cant open door
You can release the catch from inside just keep trying and thern you need to replace the door catch itself this is a simple job
Jun 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
The soap dispenser does not open to let the detergent out during the wash cycle.
Sometimes if the tablet is not put in correctly it makes the door catch jam as the tablet is pushing against the door and not leting the catch move to open. try putting the tablet in then close the door then just flick the catch to open the door to see if it opens easy. if this dose not cure it then the door catch has moved or got loose behind the door cover. with the electricty off and plug removed you migh try taking the screws that hold the main door front on and then checking the plastic arms are all inline and move easy. the door catch works on a selonoid that throws open the catch, its unlikly that this has gone open curcuit but if this is not opperating i think you need to call an engineer.
Jan 20, 2010 | Whirlpool Dishwashers
The door catch on my easi logic 1200 washing machine has broken
The door catch will have to be replaced, depending on model you can buy these from a repair shop for a few pounds.
You will have to open the machine to get to the door catch from inside.
IMPORTANT: THERE ARE LIVE SWITCHES AND MAINS SUPPLIES WHEN THE COVER OF THESE MACHINES ARE REMOVED, DO NOT TOUCH OR TAMPER WITH ANY PART, UNLESS THE POWER IS OFF AND THE PLUG REMOVED FROM MAINS SOCKET.
Remove the power supply as mentioned above, remove the top cover reach down inside and try to open the door, (BE SURE THAT THE DRUM IS TOTALLY EMPTY OR YOU WILL FLOOD THE FLOOR)
I can't advise exactly how to open the door from the inside, beacuse I do not know the make or model No.
If you are successful in getting the door open, the screws to remove the broken catch should be visible just inside the door.
Best of Luck!!
Jul 04, 2009 | Kenmore 4292x Front Load Washer
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Door opens on its own
Hi. Thanks for the question. The problem is with the door catch .On the door there should be a small piece of plastic ,sticking out the door and on te front , a catch to catch the striker.You need to replace that part thanks the appliance doc That's a fix ya
Sep 29, 2008 | Kenmore Elite HE4 Electric Dryer
Faulty door catch on my LG washer?
I have had the same problem for a week now. Until I find a spare part I slide a scraper to push the catch open. That just works.
Dec 05, 2007 | LG WM-1480FHD Front Load Washer
Dishwashers Logo
71 people viewed this question
Top Stainless Dishwashers Experts
richie46
Jack Frost
Tom Chichester
Are you a Stainless Dishwasher Expert? Answer questions, earn points and help others
