Question about Maytag MZD2766GES Side by Side Refrigerator
Freezer is not freezing on Maytag MZD2766GES
Just moved the wide by side from one house to another and now the freezer is not freezing (even on the coldest setting) and the refrigerator is not as cold as it should be. It did work for a couple of days, but now it seems like it hasn't worked for about a week.
  • 1 more comment
  • mikellychabs May 25, 2009
    To answer Techism and micbeth1981's questions:
    When we moved it, we did lay it on it's back for about 20 mnutes. When we placed it back upright, we did not plug it in for about 6 hours. It did work for a few days, but now the cold air coming form the vents is somewhat cold, but not cold enough for the freezer. I would say it is about 37 degrees (roughly).
    The compressor is running but there is no frost build up on the inside of the freezer. I have not yet taken the external back panel off of the freezer to see if there is any ice build up.....
  • James
    James May 11, 2010
    When you moved it did you lay it on it's side or back?
  • MIKE major May 11, 2010
    is the compressor running and is there frost building up in the freezer on the bach waal?mike
    Genius:
  • 1,122 Answers
When you lay a frig. on it side for any amount of time it is a good idea to let it sit over night to let all the compressor oil drain back into the comp.you might have already fouled the compressor,unplug it and let it sit for a few days and see what happens and let me know-mike
Posted on May 25, 2009
  • 59 Answers
When you lay a refrigerator on its side oil from the compressor can seep out into the tubing and cause a restriction in the sealed system. This will cause only a small amount of cooling to occur and needs a licensed technician to fix it.
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Aug 19, 2009 | Maytag MZD2766GES Side by Side...
I have a frige that won't freeze. fridge side won't get cold
This seems to be a common problem with these refrigerators. I had the same problem a while back. Sounds like your defrost board is dead. part number is 12002104. You can find it at searspartsdirect.com
Jun 27, 2009 | Maytag MZD2766GES Side by Side...
"maytag plus wide by side is not getting cold enough"
The defrost thermostat is failing on these machines as well as the adaptive defrost control.
The compressor start relay is on recall from Maytag also.
Apr 10, 2009 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
Freezer not freezing
Because it stopped cooling so fast, over night, I would make sure the compressor is running and the condenser fan motor that sits next to it.
Jan 10, 2009 | Maytag MZD2766GES Side by Side...
Maytag Wide by Side (5 years old) Freezing Refrigerator & Freezer
There is 2 things you can replaced to rectify this problem .
1 is the defrost timer and the next is the thermostat.
On the thermostat is a metal rod that is connected to a vent so when you adjust it it open or closes the vent .Just make sure that is not loose because if it's loose even though you turn thermostat down the vent would be wide open allowing freezing air to get into refrigerator.
Jun 03, 2017 | Maytag MZD2752G Side by Side Refrigerator
Maytag wide by side
Sounds like a defrost problem or dirty coils under the machine. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Aug 11, 2008 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Aug 18, 2007 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
325 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
