Question about Magellan Maestro 3225 Car GPS Receiver
Magellan maestro 3225 usb charging
I can not tell if it is charging when connected to the computer. How can you tell? All I get is a screen saying that it is plugged into the usb port.
  • 21 Answers
Go to system setting and you will see the charging icon animation and displaying battery strength.
Posted on Oct 07, 2009
SOURCE: magellan maesto car charger causes usb screen
Two exact solutions to this problem. I'm a electrical engineer and have figured Magellan GPS chargers out(sneaky you know what's..)
OK.
1) Mini USB ports wear out. They do have spring loaded gold connections, but over time, dirt gets in there and causes a loss of connectivity, so take care of them and try and clean them if they need it.
2.) Magellan GPS auto chargers are not standard chargers. They use what's called a USB 2.0 Mini-B "TYPE-A" plug. The "type-A" is important. There are 5 little pins inside that mini connector. 1:Power, 2:Data -, 3:Data +, 4:Ground, and 5:Ground. That #4 ground is important(that's what makes their charge cable unique). A regular Mini-B USB cable (like the one you connect to your computer) does not have pin-4 (ground) connected. It's left floating in plastic. So you can spend your hard earned money (like I did) and buy a bunch of USB cables trying to find one to work, but it has to be USB 2.0 mini-B TYPE-A..don't forget. Also, the Magellan charger pushes 5.2 V at a short circuit current of 1.9 Amps. That's a lot of power. Standard chargers push about 500mA to 900mA of current. The higher the current, the faster the charge. But the main trick that Magellan uses is the damn TYPE-A cables. If you don't use type A. You'll get that message "you have connected to a USB..yada..yada...yada.." , bunch of milkylickers over there at Magellan.
Posted on Jul 29, 2009
SOURCE: Maestro 3250 Charging
I accidentally ran into this problem today when I inadvertantly plugged the wrong charger into the unit. I'm guessing that the device isn't getting the precise current it's expecting and thus thinks it's plugged into a computer. I'd suggest getting hold of a different charger and see if the problem goes away.
Posted on Mar 26, 2008
SOURCE: Magellan Maestro 4010
I have bought a charger for my Maestro 4010 in the magellan's web and it's with mini-usb port... and don't charge anything!!! Incredible!!!
Posted on Jun 05, 2008
AvioriX
  • 689 Answers
SOURCE: magellan maestro 3225 (user guide manual)
Hi
You can get the user's manual from link below
http://www.magellangps.com/assets/manuals/maestro_3225_manual_en.pdf
Posted on Nov 17, 2008
  • 3 Answers
SOURCE: My Magellan maestro 3225 wont charge or start up
Same here - the problem, at least with mine, is that the power pin on the unit has become loose and not making contact with the machine - thus will not charge most likely from pluging and unplugging it in multiple times and breaking the connection inside the unit - FWIW, this GPS a real piece of **** and I have already replaced it with a Garmin- I'm trying to figure out how to take it apart to see if I can solder the power pin back in place but it is not as easy as removing the 4 back screws...
Posted on Jan 24, 2009
Hi accidentaly remove application folder on Magellan maestro 3225 GPs now its can not hookup with my computer I save my GPS all file in my computer how how I reinstall application on GPS
If it won't connect then about all you can try is a hard reset. That will force it to reload all of the applications and reset it back to factory default condition. You would loose any waypoints and routes etc that you haven't saved but it should work just fine after that.
Oct 11, 2010 | Magellan Maestro 3225 Car GPS Receiver
Magellan Maestro GPS #MM3225. Screen display this
The unit is now connected to your computer, and you can actually access its filesystem through windows. It is also charging the battery in the unit. I wouldn't want to mess around with the files, though, unless you know absolutely what you are doing. Plus, it's also a good idea to turn the unit off before removing it from the computer.
Apr 18, 2010 | Magellan Maestro 3140 GPS Devices
Magellan 3225 says it's plugged into a PC
Can you use it as a regular GPS when charged? If yes, charge it offline and use it only when charged. If not, I had the same problem. Please email me the detailed steps you have taken until you got stuck. My email is kazi at hotmail dot com.
Aug 27, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Operating system for Magellan Mastro 3225 GPS has been lost
Create an account on their website and download the firmware update. It is free and I have done it.
May 16, 2009 | Magellan Maestro 3225 Car GPS Receiver
Nov 10, 2008 | Magellan Maestro 3225 Car GPS Receiver
go to the magellen website i did i bought the gps on ebay,then went to the website to register and to download the adobe format 3225 manual,here it is https://www.magellangps.com/products/product.asp?segID=408&prodID=1992
Oct 17, 2008 | Magellan Maestro 3225 Car GPS Receiver
Need to update the maps on the gps magellan maestro 3225
I need to update the map on my 3225 Magellan Maestro, can anyone help?
Sep 28, 2008 | Magellan Maestro 3225 Car GPS Receiver
Magellan Maestro 3225 Car GPS Receiver Logo
755 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
