Question about Husqvarna Chain Saw 20" Bar
Chain oiler 357xp
Oiler on 357XP not working had gear replaced last season?
  • basecamp117 May 24, 2009
    washed out oil tank ,checked barr and blew everything out .
  • Håkan Sterner May 11, 2010
    Did you make sure the oil hole is not clogged, and that the sword oil holes are clean? If not wash properly with white spirit.
  • 181 Answers
When you say that you changed the gear,was that the plastic one?check the other gear that is on the pump itself.make sure that it isn't worn.then make sure it spins freely.if it doesn't that will be you problem.cleaning them has never worked for me.........just replace it and the plastic gear.with both being new you should have no problems with oiling.the little pump gear gets scored up inside and they stop spinnig fast enough to work properly.hope this helps let me know if you have any questions
Posted on Jun 01, 2009
Only blue and orange colour comming
It is HOCKEY season in Canada and Blue and Orange are Team Colours for the EDMONTON OILERS.
This must be a good omen for them.
Thank you!
GO OILERS GO!
First home game of the season tomorrow and
I'LL BE THERE!
Oct 14, 2015 | SAMTRON 55V 15" CRT Monitor
The bar quit oiling itself while I was cutting. I have a Poulan Pro PP4218AVX.
I had the same issue with the same model. If the channel is not plugged, it's probably that the oiler mechanism has to be replaced. According to all the experts in the field, this oiler is a poor design and needs to be replaced occasionally because it is a mechanical "plastic" gear that wears out rather fast. The part is not too expensive and it's fairly easy to replace. My new one is still working after 1.5 years of use.
Good luck! Plse rate this answer! Tks
Apr 15, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Oiler doesn't work
check the oiler worm gear and make sure it is in good condition and that the arm isn't loose or the tip broken off
Oct 12, 2012 | Stihl Garden
Ihave never been able to get the automatic oiler to work on a Poulan Wikd Thing 18" chainsaw. I have replaced the spring drive, bought a spacer tool for the spring drive, replaced the plastic gear,...
It is a fairly simple oil pump system, the spring gear on the crank will fit on either way, however the spacing of the coils is is critical, there is a small plastic tool to do this, i think you said you had this tool, it has to be an issue with the pump, the gear not only turns but has a throw, the amount of throw denotes the amount of oil delivered, a small steel pin in the side of the pump body works in a cut a way in the pump shaft, has the pin fallen out? just cant think what else you can do as you seem to have done everthing.
Apr 12, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain oiler not working
replace the oiler assembly
nylon gear frequently strips gears
replacements only cost around $10.00
Sep 10, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
I need to know how to adjust the bar oiler on my husqvarna chainsaw
A link to an OM for a 2005 Husqvarna 357XP/359 follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_1150046-95.pdf
The procedure is on page 35.
CAUTION: It only has 3 positions; forcing it beyond the stops may render it inoperative.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 13, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
McCulloch EB428 chainsaw and the auto oiler won't work
Good on you for what attempted already. I looked at the print and it appears there is a worm gear (item 50) and a driven pump (item 61) behind the clutch. I suspect one of the 2 has failed. I know you have done most of this already But does it ooze with the bar off?
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
A link to the only IPL for a McCulloch EB428 follows:
http://www.ordertree.com/modelinfo/MCC/EB428-Chainsaw/139.EB428-Chainsaw.1.59.1.html
Lou
Apr 30, 2010 | McCulloch Garden
I have 3 older Poulan chain saws, XXV, 1800, and 2000, essentially identical saws. They all use a check valve from the crankcase to pressurize the chain oil reservoir. The check valve apparently uses an...
These oilers are called diaphragm oilers and work fairly well when the saw is new with great compression. As the saw wears out, the compression drops and a side effect is less oil pumped. The diaphragm is replaceable and it's not horribly expensive. Most good saws use a gear oiler - and even the newer Poulans use gear oilers. The gear oilers tend to have less problems and don't rely on engine compression.
Oct 09, 2009 | Garden
Husqvarna 357 XP Hard starting when warm.
I work for warcks county council, the husky 357xp is our main saw. We've experienced the same problem with many of our new 357's. after many hours of trying to solve the problem (including swapping carbs from old broken saws etc) i stumbled upon, by fluke i'm afraid, a problem with the ngk bpmr7a spark plugs. They seem to work fine for a short period of time (even new out of the box) then leak compression from the cylinder. We are running a esser rated bosh spark plug which seems to have eliminated the problem, (can't remember the number, sorry). We have now ordered champion plugs to replace the stock. Probably worth a try. Hope this is of some help.
Kieran Tursner
Mar 04, 2009 | Husqvarna Chain Saw 20" Bar
I have a 455 Rancher got it slightly used. It had oiler issues when I got it took it to the shop they installed a new one 3 months later the oiler isn't working,any fix for this?
the rancher uses a plastic oiler gear to a metal gear.the plastic gear always looses in the battle.pull the clutch off and clutch drum.under the drum you will find the plastic gear.replace it and all should be well again
Feb 21, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
250 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
