Question about Canon PC-950 Black and White Copier
Urgent after taking a copy images coming fully black. my technician suggest me to replace logic pcb which fits at back side pf canon copier pc 950 model. i have 3 machines . can i get the logic card. whats the price. also guide me the problem dignose by my engineer is correct or not. nitin
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,346 Answers
Re: urgent
Does the lamp come on when making a copy? No, check lamp for continuity.
Did he check the fuse ( or diode) next to the lamp? replace.
If those two are o.k. then it's the pcb.
Also, check under the drum there are some wires in an assembly are they broken replace.
There is one more single wire on top of the drum, check.
Here is a good site for parts, and cheap yours is only $27.00 for the board.
Posted on Nov 01, 2007
0 characters
3 Points
Print is fully black
often when the exposure lamp burns out, all your copies will come out black. The light reflects off the immage to the drum to create the copy to be printed to the paper. If the light is out, all the drum will see is a black image to be printed. Make a copy with the cover open, and see if the light turns on.
Nov 04, 2014 | Canon IR2016J
Replacement platen glass cover for a pc950
There is a locking pin through the leg of the cover, you need to take off the back cover to get at the pin
Dec 30, 2010 | Canon PC-950 Black and White Copier
remove the image processor pcb and the ram. wash it with petrol and then dry it. insert it in the copier. if the problem comes again then replace the pcb's
Aug 11, 2010 | Canon imageRUNNER 2200
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Jul 02, 2010 | Canon Printers & Copiers
Canon IR 2016J Scanner does not move and glows while copying
Call service it may be lamp pcb or broken belt or ...
Apr 08, 2009 | Canon CLC 1140 Copier
Canon PC921 copier has blurry section on copy
what you probably brushed over was the transfer roller(black and spongy?). first try running 20 or 30 blank copies through the machine. If that doesnt work take a dry paper towel and gently wipe and rotate that black roller. that should take care of the problem. If the roller needs replaced you should have a technician do it. You could break the machine beyond repair.
Apr 07, 2009 | Canon PC-921 Black and White Copier
Top feeder not working MF6550
One or both of the ADF hinges are bad. The ADF cover doesn't close all of the way causing feed failure of the original and shading on the side of the copy because the scanned original is not fully contacting the **** exposure glass on the front operators side.
Feb 27, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Canon PC-950 Black and White Copier Logo
51 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
