Question about Microwave Ovens
Display reads F6. Will not clear. Microwave runs wenever plugged in.
  • 1 more comment
  • donnybowling May 26, 2009
    Display reads F6. Kenmore 665.61701100
  • donnybowling May 27, 2009
    kenmore 665.61701100
  • William Miller
    William Miller May 11, 2010
    That may be a shorted cook relay or keypad, but either can be repaired pretty easily.
    Please reply back with your brand and model number so we can help you.
  • Microwave Ovens Master
  • 9,085 Answers
Okay, thanks.
Looking at the tech sheet, that would be a shorted cook relay on the control circuit board, which we can repair for you for $39.95 in about a week or so.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 27, 2009
Getting an "F6" error on
HELLO.
An F6 error code typically indicates a controlpanel problem. Disconnect power and wait several minutes before plugging itback in. If the F6 error code comes back within a minute of restoring power,the control switch pulse return line is not connected properly. This willgenerally require professional repair.
Thanks.
Sep 21, 2011 | Kenmore Microwave Ovens
Microwave is humming when off display says F6
We had a power failure for 2+ hours. I went to defrost something when the power came back on. Somewhere along the line the F6 popped up. With the door closed it sounded like the machine was running.
I slapped the side too and it worked. I pulled the vent cover off to clean it and found the tech sheet stuffed in a bag inside. I found what F6 means. 'Microwave relay failure. Check wiring to relay 4903 for short circuits. If wiring is ok, replace control board' Then, of course, a whack on the side by the button panel worked
just as well. rek('_tx6');
Reference: It means the relay is stuck in the run position. Apparently if you slap the unit hard enough it will unstick the relay and allow it to work properly again. rek('_tx7');
Aug 06, 2010 | Kenmore Microwave Ovens
My Microwave is displaying F6 and running when plugged in.
I found a sheet that says to check wiring to main or microwave relay for shorts. If no shorts found, replace control board.
Apr 10, 2009 | Whirlpool GH7145XF Microwave Oven
I replaced the light bulb, now it displays -F6- and pushing any button causes a humming noise.
I left the unit unplugged over night, plugged it back in the next day and still had the same problem.
Oct 13, 2008 | Roper Microwave Ovens
Kenmore microwave
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Sep 09, 2008 | Microwave Ovens
Microwave oven
I'd bet the first three digits of your model are 665? That would make it a Whirlpool.
Either way, the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
It may be a problem (such as a missing timing pulse) on the control panel. We repair these.
Mar 17, 2008 | Microwave Ovens
Kenmore Microwave hood combo Model # 66569689992 F6 error code?
Dec 08, 2007 | Microwave Ovens
Microwave repair
my kenmore 665 69682992 2000 model was running fine until it stoped while i was defrosting and the display appeared f6 and continues to run, what should i do.
Mike hammoud
8465 berwyn 48127
dearborn heights Mi
313 2829272
Jul 04, 2007 | Kenmore 63792 Microwave Oven
Microwave won't work
F6 usually means a fault in the controller or keypad. You could try to unplug it for several minutes, then plug it back in. If it still fails, maybe you or a friend can disconnect the power cord, unplug the keypad strip internally, then plug the power cord back in and try it with the keypad still disconnected. If it does not fail again, you have a wet or shorted keypad and can dry it or order one. If it does fail again, the control board is bad. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 Sorry I didn't get to answer this before the bogus answer was posted. I've been tied up and away from the PC.
Apr 01, 2007 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
110 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
