Question about Whirlpool GHW9400 Duet Washer
No Power at Control Panel
My Whirlpool Duet WFW9400SW00 will not 'power up'. When the unit is unplugged and plugged back in, there is only a quiet 'click' and no power at the control panel. The unit is only a year and a half old and has already been through the whole F20 problem and mixing valve repair, after several months of not working!
  • 3 more comments
  • mtjones May 24, 2009
    Thanks.  How exactly do I check the fuses?
    The literature that came with the unit does not provide any details. There is a beige plastic 'box', secured by two screws and four plastic clips at the top rear of the unit, where the incoming power enters and the end of the 'whip' to the control panel exits (with two pink wires).
    Is there a fuse in that unit?
    Thanks,
    Mark
  • mtjones May 25, 2009
    There is no reference to fuses in the literature with the machine.  The power cord enters the beige 'box' noted in my last message.  There is no obvious fuse there.
  • mtjones May 28, 2009
    There are no fuses at the back of the unit.  Could there be a fuse in the MCU/CCU?
    Also, could it have anything to do with the Interference Filter, which IS at the point that the power enters and unit and the only thing before the MCU?
    Problem Solver:
I have the same problem- a week without my washer and now I dont know if its cheaper to just buy a new washer or if my duet is fixable! I get no power, no clicking sounds, dont know what to do! Where can I check for fuses
Posted on Jan 15, 2010
    Sergeant:
    Champion:
  • 212 Answers
Sounds like a fuse issue. check the fuses.
Posted on May 24, 2009
  • Robert Lekfield May 24, 2009
    should be in the back of the machine where the power cord is. If you have a owners manual check it.
  • Robert Lekfield May 28, 2009
    It could be. Contact whirlpool to find out where the fuses are. they should know. The Interference Filter could be bad.
My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Dec 31, 2010 | Whirlpool GEW9250 Electric Dryer
I have a front load whirlpool Duet washer I stopped the wash cycle to put more clothes in now it just flashes the time left in the cycle but will not restart what can I do?
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET TROUBLE CODE F15
F15 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit to check wire harness connections to the motor, MCU, and Central Control Unit (CCU).
Check the drive belt and reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor and check the drive motor for powered rotations.
Replace failed component.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Determined the problem with my frontload Whirlpool Duet washer...the drain was definitely clogged. How do I reset it? Do I unplug it?
Apr 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset a whirlpool duet washer
Oct 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No codes on a whirlpool duet ft loaader. can they be reset?
Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
NO POWER JUST BEEPS F70 CODE
Bad main control or ccu here is a link to the repair manual.
http://www.affordableappliance.com/Download%20Folder/Whirlpool%20Duet%20Washer%20Service%20Manual.pdf
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet WFW9400SW00 - How do I remove the control panel?
The ccu isnt behind the panel. The ccu is under the top of the washer. Who will be repairing this? This is a non- reparable part.
Jul 01, 2009 | Whirlpool Washing Machines
Hi - I have a whirlpool duet washer with a flashing F 07 error. What is it?
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
591 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
