Question about Sony FD Trinitron WEGA KV-27FV310 27" TV
Philips 29 in silver color
I have recently had cable tv install and now all of a sudden. The t.v turns off when it wants. The green light is still on indicating tv is on but no picture. After awhile that light will go off. Then i will push the power button and it clicks on but after a short while it will click back off..Any solutions to this problem. I had the tv directly connected to the cable box and i unhooked it and plugged it into the regular wall outlet and its still doing the samething. I removed the tv and placed another there and it worked fine. So it makes me think its the tv but at times it will play long time, then other times it will click off every one minute or so then i have to turn it on and off to see the picture screen appear again.
  • 979 Answers
Re: Philips 29 in silver color
Intermittent HV feedback loop circuit will cause this. Also dust and ambient temperature play a large part in this circuit's operation....accordianman
Posted on Oct 20, 2007
0 characters
3 Points
Problem with a Phillips 32 in TV green light blinking
There is some problem with main board. Seek tech support
Jun 02, 2012 | Philips Standard (CRT) Televisions
Philips 30PW850H 30" TV screen is completely
normally color crt tvs have three guns such as red green and blue. when the voltage at the cathode any of these guns go to zero that color will lead in the screen.
in ur case the green cathode voltage is low. that's why the is green on all over the screen.
if it suddenly came then there is a possibility of dry soldering in the pcb behind the picture tubes neck. we called it as base board. which consist of three transistor or one ic for cotrolling cathode voltage of the guns .
if u have a soldering iron the open ur tv and try to re-solder components in the base board. mainly the component with three leg ( if transistor). if there is ic it will have more than 6 legs . if you can try to re-solder all the points. Be care-full that dot make short circuit when soldering. after care full soldering power on the tv and watch the scree. you problem Will solved.
if u need any further assistance from me, feel free to contact me through fixya.
Jan 16, 2011 | Philips 30PW850H 30" TV
Philips 32PT6441\37 will not turn on. Flashing
You need the Horizontal Timing Kit for your TV. Chassis # is L04.1U AA can be found on the back of the TV. The part# is 4835 310 57673, Have a tv tech install this for you.!!!!
Oct 17, 2009 | Philips 32PT6441/37 32" TV
Power seems to be on, but it does not turn on
There is a loose connection inside the TV or component damage, it need to be repair by resoldering the component first.
May 31, 2009 | Sony KV-32S26 32" TV
Phillips tv no color
most likely you have a burned out ligt bulb inside tour tv
Apr 11, 2009 | Philips 20PT643R 20" TV
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Where to buy CRT TV Philips tube ?
Picture tube will not cause NO color problem, color circuitry problem.
Jul 18, 2008 | Standard (CRT) Televisions
Colored Lines Destorted Picture
I had the same problem , sent it into the shop and they said it was a capacitor . It is a $3.00 part and $75.00 for labor . But it did fix the problem . The labor charge was inflated I'm sure so if you someone who can do it and just get the part ,would be the way to go.
Apr 13, 2008 | Philips 32PT5441/37 32" TV
Green horizontal lines
Hi, I have a Philips 29PT9009/12 TV. Recently I have begun to see horizontal green lines on my tv, when either watching a dvd or watch tv. This has gotten worse and now the green lines are more visible and the background is now turned a shaded green. Please help me. Thanks in advance
Apr 30, 2007 | Philips 28PW6506 28" TV
Sony FD Trinitron WEGA KV-27FV310 27" TV Logo
46 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
