Question about Bose Lifestyle 25 System
Bose Lifestyle 35: plays DVD but no picture
Inserted DVD,selected CD/DVD input, DVD plays, audio works fine but no picture
techman
  • 3130 Answers
SOURCE: lifestyle 12 by Bose
No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
Posted on Jun 14, 2006
SOURCE: Bose lifestyle DVD only playing black and white.
We had the same issue. The svideo cable was no longer connected. It had become unconnected when we were connecting a game system.
Posted on Dec 20, 2008
SOURCE: System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Posted on Feb 05, 2009
SOURCE: Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Posted on Feb 24, 2009
cjackHD
  • 71 Answers
SOURCE: Bose Lifestyle 48 System play's dvd in black & white only
Your s-video cable at the back of your media center is loose. This will cause black and white internal video and is known to fall out or just become loose from minor movement. (it's the nature of s-video cables) This should solve your problem. This is the s-video cable that connects to the VS2 and media center.
If this doesn't solve the problem (I'd be surprised), just reset it by unplugging the DC power cable at the side of the VS-2 for about 30+ seconds and plug it back in..
Posted on May 31, 2009
My bose lifestyle 48 say resolutio not supported when i try to play a dvd but i have sound without a picture. how can this be fixed
Is it a copied DVD or DVD-R / RW? If if says resolution not supported then it means that the DVD has a video format that cannot be played on the Bose even though the sound track is fine. The DVD may work fine on a PC as these can usually play more file types, but it could be a number of things causing it not to work and unfortunatetly there is nothing you can do.
Jun 29, 2014 | Bose Lifestyle 48 System
Black and white
The Lifestyle 38 has no HDMI output. It all depends on what inputs your TV has, which cable set up would be the best for you. Assuming that your TV has an SVideo input, you indeed can use the SVideo output of the Bose system, to get the DVD picture on your TV. However you will need to connect the audio output of the TV to the TV input of the LS 38 to get the TV sound to play over your LS 38. In case you don't have an SVideo connection on your TV, you can use the composite output of the Bose system and connect it to the video input of your TV (yellow in and outputs)
Dec 10, 2013 | Bose Lifestyle 38 DVD Home Entertainment...
When playing a dvd the color is in b&w only
I have had exactly this problem when changing TVs. Initially I had the sVideo out cable from the Bose with a scart plug on TV end - that worked fine on old TV. On new TV, first Samsung, second SOny, got Black and white video picture. To get it to work I used a component video cable - this is a short svideo cable with a an audio cable at the Bose end. It splits into a 3way R G B cable within 2- 3 inches at Bose end. I then plugged rgb extension cables into this and TV and worked perfectly.
I found the answer to this by errr...... reading the BOse doucumentation I reveived when I bought the Lifestyle system 5 years ago.
Good luck
Peter
May 15, 2010 | Bose Lifestyle 38 System
I have a Bose Lifestyle 35 Series II and want to know whether it's compatible with a DVD+RW. I'll burn it in a Toshiba recorder, finalize it and then play it on the Bose. Will it play?
Hi This what Bose say about formats
"The Lifestyle® 35 system plays DVD-video in interlaced format, as well as music on CD, CD-R (recordable) and CD-RW (re-writable). The system also plays MP3 files on CD and AM/FM radio. "
So by the sound of this i suspec that you may struggle with DVD/RW. but my best advice is try it.
Nov 10, 2009 | Bose Lifestyle 35 Series II System
My bose lifestyle 35 system does not play divx dvd. I do i enable divx dvd.
DivX compatibility is not a feature of the Lifestyle 35 system. You can contact Bose Support, to inquire as to whether they have any firmware upgrade for DivX compatibility. To the best of my knowledge, there is no such upgrade in existence for the LS35.
Oct 16, 2009 | Bose Lifestyle 35 System - black Theater...
Can't get sound on tv but dvd and radio work.
Sounds like an install problem. All of your inputs (audio and video) should run through the BOSE and then only the video out needs to run to the TV. In this way the BOSE is the sound source for everything
Aug 30, 2009 | Bose Lifestyle 48 System
Bose lifestyle 48 says format unsupported for audio cds
Everytime I want to play an audio cd, it says format unsupported. This is happening very often. And I have also cleaned the cds,but still there is no difference. What is the solution?
Apr 08, 2009 | Bose Lifestyle 48 System
hi there,
good luck
Jan 31, 2009 | Bose Lifestyle 18 System
TV audio through Bose Lifestyle 38
Did you select TV input on your AV38 Bose system and same thing for VCR. it should work unless from your TV audio if you watching HD signals some of the program had copy protection so it turn off the video and audio out at your TV output monitor that for TV
For VCR it must work make sure you select VCR input on your AV38
I hope that give some ideas
Dec 15, 2008 | Bose Lifestyle 38 System
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
Bose Lifestyle 25 System Logo
436 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
