Question about HP LaserJet 1020 Printer
Who to open the printers
I required documents for openting the HP Printers
    Sergeant:
    Champion:
  • 212 Answers
Go to www.hp.com for the documents for it.
Posted on May 24, 2009
HO C4200 DOCUMENT STUCK IN QUE CAN'T DELETE
First You Need to Open the Print Queue, follow the below steps on how to open a Print queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double click on the appropriate printer to open up the Print queue,Check whether you have any pending or the queued jobs, try to cancel the jobs by following the below steps.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
• To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
• To cancel all print jobs, click Cancel All Documents on the Printer menu.
If you are using an HP printer and a windows vista operating system then you are lucky to automaticlly fix the issue with the HP Print Diagnostic UtilityClick Here For How to cancel printing or to delete a print job that is stuck in the print queue in Windows XP.
Alternatively You can check the below steps.
Delete Pending Jobs
How To Restart Spooler restart In Windows Vista
Click the Start button.
Click Control Panel.
Click System and Maintenance.
NOTE: This step is not required when using Classic view in Windows Vista.
Click Administrative Tools.
Double-click Services.
On the User Account Control window, click Continue.
Click Print Spooler.
Click Stop to stop the Print Spooler.
Click Start to restart the Print Spooler. Then click Restart
Click OK
Hope this helps!
Thanks!! - See more at: http://hpanswers.blogspot.com/2008/10/cancel-and-delete-stuck-print-jobs-in.html#sthash.QD3KNI9q.dpuf
Jul 01, 2014 | HP LaserJet 4200 Printer
Hp 2727 document feeder does not fully expell the document into the receptor tray causing a bad copy at end of paper.
This error is either a bad ADF or a bad cable that connects the ADF to the scanner. Either way it requires a replacement of the ADF. This is a known issue with this series printers.
Jul 07, 2011 | HP LaserJet 2727NFS All-In-One Printer
HP lazerjet 3055 is showing document loaded and will not clear how do I clear this. please advise.
Try this:-
Go to your printers folder. You may access it from start/control panel or simply start/printers and faxes depending on your operating system. there right-click on your printer and click open. When it opens, select the sent documents shown and click on delete. You may need to repeat the procedure to completely clear all sent documents that failed to print.
God bless & Good luck!
Mar 01, 2011 | HP LaserJet 3055 All-In-One Printer
GOT 33 PRINT JOBS IN QUEUE L IKE TO DELETE THEM FRO HP OFFICEJET PRINTER4680
Hi hunter707515
under Win XP :
go to start \ settings \ printers and faxes , select the jobs , clic on documents and cancel .
under Win 7 :
go to start \ devices and printers . Right clic on the printer , select open \ documents in queue \ select documents and cancel
Best regards ,
fanaudi .
Feb 27, 2011 | HP J4680 Office Jet All-In-One Printer
I have a hp 1310 AIO Printer how do you scan documents to computer using such programmes as ms word
MS Word cannot open scanned documents to edit. You need to run a scanned document through an OCR program (optical character recognition program) which converts the scanned document into a text document. Then you open Ms Word and import or open this text document to edit or change the text.
Nov 25, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Im trying to cancel a print job and all i get is Operation could not be completed (error 0x00000005)access is denied what do i do
open the print que and delete the job there.
controlpanel, printers, open yours, delete the job.
it may be that you are required to have administrative priviledges to do this. If this is your computer, go to the control panel as an administrator user and change your user settings.
Oct 26, 2009 | HP Officejet J5780 All-In-One InkJet...
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
Why will my printer print from the internet but wont print an email?
Is your printer set up correctly, when you print form e mail, look a the page propertied..
Clcik File, Print, a window should pop up make sure you select the correct printer to printer..
Or opent the controol panel, open the printers and faxxes folder..
Make sure the printer is set as the Deafault Printer... Right click on it, select "Set As Default"
Nov 04, 2008 | Office Equipment & Supplies
HOW DO I OPEN THE CRADLE LATCH OF HP 5550?
You've been very careful not to do what you think would break the top cover.  But sometimes you have to take a risk and trust the instructions which tell you to "Open the top cover".  Yes, it's going to require a bit of a jerk to get it open.  If you go to the HP website there's a picture which shows that no release buttons or latches are involved.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09327&lc=en&cc=us&dlc=&product=71896
good luck!
Oct 14, 2007 | HP DeskJet 5550 InkJet Printer
HP LaserJet 1020 Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
