Question about Dell Inkjet 720 Printer
Light blinking when changing cartridge.
Cannot get cartridges in center to be able to change them.
    Sergeant:
    Champion:
  • 212 Answers
Turn it off. try to slide it with your hand. If that doesn't work turn it back on and hit the reset button.
Posted on May 24, 2009
The orange ink cartridge light keeps blinking. We
the problem is that your cartridges are expired or bad, just replace the two cartridges with a new one
Mar 16, 2010 | HP DeskJet 940c InkJet Printer
Its stop printing and the LED power light green and orange at the center blink, like there is a paper jam.
Feb 11, 2010 | HP DeskJet 1280 InkJet Printer
Red ink light blinking, won't feed paper. Have
this is hp security error, for ink cardtridge,(the ink cartridge has internal/acess counter), you need to try change cartridge, if contuinue send to hp service center
Nov 27, 2009 | HP DeskJet 940c InkJet Printer
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
I open the case to change the print cartiridge, but the cartiridge holders remain on the left hand side, and will not come to the middle for me to change. and the green on switch keeps blinking while it is...
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Oct 02, 2009 | Lexmark PhotoJet Z705 InkJet Printer
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | HP Laser Jet 1320 Printer
Orange blinking light at cartridge icon
The Amber light is designated as the "Ink Error" light. With regards to a 960C Hewlett Packard or almost any inkjet printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Sep 10, 2009 | HP DeskJet 960c InkJet Printer
Diskjet6122 the light that looks like a tear (right below the X) keeps blinking. Cant get the printer to print after I changed the ink cartridge.
The indicator light blinks, it says you're low on ink in one or both cartridges. If you've changed cartridges and it still blinks, you may have stuck or dirty pins in the cartridge station(s). Use a damp, lint free cloth to make sure the pins are clean and move freely
Jan 20, 2009 | HP DeskJet 6122 InkJet Printer
Black light & print cartridge light is blinking. I changed the black cartridge but did not change the color cartridge cause I never use color. Both are in the printer. Black Light is blinking and...
Unfortuantely , to solve the issue , sadly, yes you will have to replace the empty cartridge to continue to use the printer in a normal fashion. Its a sneaky and dirty trick many printer manufactuers do to make more money off of the customer through the purchase of printer ink.
Aug 25, 2008 | HP Computers & Internet
Lexmark x73 all in one
paper was jamed at one point turn off printer with no paper in cartriage turn printer back on
Oct 23, 2007 | Lexmark X73 All-In-One InkJet Printer
Dell Inkjet 720 Printer Logo
52 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
