Panasonic KX-P2023 Matrix Printer Logo
Posted on May 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Prints one line per page
I want print to fill page before going on to the next.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 212 Answers
  • Posted on May 24, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
212
Questions
0
Helped
90611
Points
556
Check your printer settings. go to preview print page before printing. Might have to uninstall printer and reinstall it again. Hope that helps You.
Hp deskjet 5550 printing only a few lines per page
The printer driver is corrupt. Uninstall it from the computer before trying to reinstall the driver. If you don't have the driver CD you can go to HP's website and download it.
3answers
My Business Cards
You need to set the print size to match the size of the card.
you either need to resize the document or change your print preferences to match the size of the card.
My Brother HL1230 printer prints with whole lines of text missing several times on a page and gets worse by missing more lines if printing several pages. It has a new toner cartridge. How can I sort this...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
1helpful
I have an I Mac 10.58. I have typed into an Address Book 62 addresses that are stored on an Address on an a group labeled "Xmas Group." Separately I have typed into "labels" the #8167. What is the...
Have the group selected and then select print from the file menu.
Make sure that the arrowhead next to you printer name is pointing upwards.
Under the from to page selector it should say Address Book.
Below that is should say Mailing Labels
On the next line down select the 'Layout" tab.
Check that you have selected US letter then select 8167.
Then hit print.
That's all there is to it. I just tried and it printed 4 columns of 20.
1helpful
When printing lines are running through the sentences.I have a brother mfc440cn printer
Good Luck
RK
1helpful
Whenever I turn the printer on it just keeps printing little weird symbols like one or two lines per page and then goes to the next page and does the same thing just different symbols and it goes on and on...
There is a job in the print queue. At the start of a print job a code is sent saying print the following data as graphics because you have turned the printer off it thinks that all the data is text. You need to delete the job in the print queue. Select the printer in Control Panel>Printers and it should show you a list of print jobs. Delete them
Canon C5185 networked printer. Printed a 437
you are filling up you memory, inless you want to buy more memory, you have to do it in steps.
if you reduce the output quality to draft, you can get more pages per set.
2answers
Printronix P5210 line printer HOF problem
If you are using a printer that has IGP enabled, you can set the printer to automatically go to the next TOF at the end of the print job. Only if you are using the Graphics portion (printing bar codes and graphics). The option is "Auto FF at ^PN" and you would Enable it.
1helpful
Possible Print Head Issue
Select the Jet Substitution Mode.
  1. On the Control Panel, select Troubleshooting, and then press the OK button.
  2. Select Print Quality Problems, and then press the OK button.
  3. Select Eliminate Light Stripes, and then press the OK button.
  4. Select Jet Substitution Mode, and then press the OK button.
  5. Follow the Control Panel prompts to select the color and malfunctioning jet number indicated on the Light Stripes Test page.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
