Question about Zhumell Yukon NVRS Titanium 2.5x42 Night Vision Rifle Scope Gen 2+, 26021 w/ FREE UPS
Name of scope . Yukon . Problem : I tried to replace a battery in the dark. Removed the wrong part by relative force . Scope damaged. Two tubes on the front of the scope one is the battery tube and th
Name of scope . Yukon . Problem : I tried to replace a battery in the dark. Removed the wrong part by relative force . Scope damaged. Two tubes on the front of the scope one is the battery tube and the second is the one which was broken off has two wires which were broken off and is optical on the end with a lens. Help can this be repaired? Yukon night vision scope titanium 2.5 x 42 Help can this be repaired?
  • 2,100 Answers
I would strip the wires as carefully as I could and get them back together, get the 2 AA batteries back in there, and see what happens. Then go about making a permanent splice in the wires and getting the lens to stay on there, or ship it back to Russia for repairs. Or find somebody to do it. I'm sure it can be done. Hope this helps.
Posted on Apr 19, 2010
When I disassembled my Gamo scope (3-9x32)to clean the lenses I removed the inner tube of the scope (erector tube) with a part of metal which work as a spring force against the pressure of the elevation...
By the length of time this question has been up and unanswered
There is no polite way to say what is required
So I will try
DONT DO THAT AGAIN TO ANOTHER SCOPE AS ALL YOU HAVE IS CHEAP SCRAP THAT WAS A TELESIGHT
Apr 21, 2012 | Gamo Optics
Scope is fogging up and appears to not be clear. Tasco 3x16
Fog in the scope means moister inside. You can try and dry it out, take the rear lens off and using a hair drier heat the tube and the lens separate. Do not blow air inside it may damage the cross hairs. You can try and pressurize the tube so it will not happen again. You will need a large clear zip lock baggy the biggest you can find. Once your scope has been heated with the hair drier. Put the scope in the bag. and try to draw out all the air inside. You can use a Vacuum cleaner. if you get enough air out you can reinstall the adjustment lens on and the tube should stay in a vacuum for a season or two. You can also put vasiline on the threads to help seal the vacuum. You can also try to use gas, you can use gas from a paint ball gun cylinder to pressurize the scope. Put the scope in the bag pressurize the bag and reassemble the scope with the gas inside.
Jan 09, 2011 | Tasco Optics
I can see objects through the finderscope, but cannot see anything through the telescope. What am I doing wrong?
Your finder scope is NOT lined up with the main tube. Get a distant object like the top of a telephone pole into the eyepiece of the main telescope tube.
Without moving the scope adjust the crosshairs or the red dot onto the exact same spot. Now your finder scope is lined up with the main telescope tube.
Dec 27, 2010 | Edu-Science (10166) Telescope
It's like new and hardly used. It starts to come on and you can see the green in the lens, then it goes dark. still shows power is on. I've tried fresh batteries with the same results. Where can I get it...
Hello. you do know that NV devise are to be used during the black hours of the night. Any type of bright lights will burn out the multi-plate coating. It only take a few time and the image intensifier tube is gone. The generation 3 and 3+ image tubes have auto gating that is, if the sensor detects bright lights with shut down. Now, this help but bright light with even the generations of image tube. It will still destroy them.
To get repaired you can send it to ATN in California. Just for them to take a look and see what wrong will $100+ plus shipping both ways and the cost of parts that is, if they have the parts.
What they will try to do, is that they will take your 258 scope in for trade. Then have you up grade from this 6 year old NV scope to a new model. They could also tell you it's not repairable.
Now, I have repair a few of the MK ATN NV scopes, and all the image intensifier tubes are manufactured in Russia, and there is good possibility that the hole scope was manufactured there.
The Russian manufactures will just print the American Vendor name and logo on the scope, monocular, binocular that they manufacture. You send to me and I will take look at and try to find a new image tube for it. drawbridge21.q.com. GB...stewbison
Nov 22, 2010 | ATN Aries MK-258 Weapon Sight
I couldnt zero my leapers 3-9x50 airsoft scope. My shots keep going right. i tried turning the knob to the left (clockwise) until I couldn't turn it anymore. I thought there was something wrong with the...
it could be a faulty mount or a loose mount or you may need to "pack out" the scope to give you more movement 3 strips of 35mm camera film should do,,just pack it at the side of the scope between the scope and the mount
Sep 03, 2010 | Leapers 5th Gen 39x50 AO MilDot Rifle...
I have the 6x18x65LU atn rifle scope. I had the scope mounted to my 30-06 on two 1" weaver rails. the scope keeps sliding forward though the adjustable scope rings. I've been recentering the scope and...
be cearfull you dont crush the scope tube,,but try rapping a little strip of sticky rubber or plastic tape round the scope tube then nipping the scope ring caps down onto this,,,but i think your scope rings are worn out or the wrong size,,ie 30mm not 25mm
i have air rifle scope's on my 7.62/308 and on my 303 none of them move about at all and they have stayed on zero for years now!
Aug 25, 2010 | ATN 6-18X65LU Daytime Rifle Scope
Will not work after dusk.Does NOT enhance any extra daylight!
I think you are a little mixed up with what a low light scope actually is.
If you look through a standard scope and a low light scope at dusk and compare the image, you should see a little clearer with the low light scope.
These are designed to allow you 10-15 minutes extra shooting time over a standard scope in low light conditions.
If you want to be sneaking round in the dark like snake from splinter cell, i'm afraid you have the wrong bit of kit.
You will need a Night Vision scope which use infra red and an image intensifier to amplify the light and convert it into an image that the human eye can see.
RobbieP
BSA Owners Group
Nov 22, 2009 | Leupold ® Rifleman® 3-9x50 mm Scope
The yukon NVMT 4 was turned ON and then flashed. Cover was on. Now the ON lights, IR Light works but visor is all grey and appear small lighting on bottom corner.
The scope may flicker or flash when used in a bright environment. To fix this you should only use a NVMT in a dark. It will restore itself in a few minutes or hours, depending on how long it has been exposed to light.
It may also flicker for the first several seconds of use in dark, before the device corrects itself.
With a severe exposure to bright light for prolonged time the light enhancing unit may damage beyond repair.
Oct 20, 2009 | Yukon NVMT (4x50) Monocular
Yukon spartan my pic is not clear light works but cannot get focu
Define 'clear'.
Is it blurry? Focus the scope or clean the lenses.
Is it distorted? Don't know how to fix. Especially if the lens is cracked/scratched etc.
Is it dark/snowy? Put fresh batteries in.
Do you see black spots in the tube? Don't worry, certain amount of these are quite acceptable.
Anyway: It's a night vision for pete's sake. The picture won't ever be like the one on normal binoculars.
Jan 17, 2009 | Yukon 24021 Monocular
Will nikon replace scope tube on buckmaster 3x9x40
Call customer service and find out. They should have a toll free number. Email might work as well.
Nov 10, 2008 | Nikon ® Buckmaster® Rifle Scope - 3-9 x 40...
Optics Logo
230 people viewed this question
Top Zhumell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Charles T Nevin
Charles T Nevin
Are you a Zhumell Optic Expert? Answer questions, earn points and help others
