Question about Amana 25.8 cu. ft. Side-by-Side Freestanding Refrigerator SRD26VP
Broken light switch on fridge door
I have an Amana DRS2462B side by side fridge. The light switch to the fridge actually broke off. Is this something we can replace ourselves and where do we find the part? Thanks.
  • Amana Master
  • 3,361 Answers
Any appliance parts store can get this switch.
Yes you can DIY. Take a butter knife and CAREFULLY pry the broken switch from the cabinet. Be careful not to scratch the plastic liner around the switch.
Remove the 2 wires, place them on the new switch and POP the new switch in place.
If this is a half-moon switch make sure it is installed in the correct direction.
Posted on May 24, 2009
Samsung SR 61KTC fridge not cooling but freezer is fine fans seemed to be very noisy a few days ago now sound like not on at all
Had the same problem when the door switch broke. The electronics of the fridge thought the door was open and therefore the fridge would not cool. I noticed that the light wouldn't turn off when the door was closed to discover the switch was broken. It was an $11 part which my husband replaced and the fridge works fine now.
Mar 16, 2014 | Refrigerators
Where do buy a filter for amana DRS2462B?
Yes you can buy this filter from online sites.Click this link directly to buy the filter:--- http://www.repairclinic.com/PartDetail/Water-Filter/1446373 ------------- To see how filter looks see the fig below:-- helpmech_51.jpg
---------- this will help.Thanks.Helpmech.
Jan 20, 2011 | Amana DRS2462B Side by Side Refrigerator
I HAVE AMANA FRIDGE FREEZER AND THE DOOR SWITCH IS BROKEN BUT THEY NO LONGER MAKE THE PART. ITHINK I MAY BE ABLE TO USE THE MAYTAG PART
Yes, if the maytag part fits, then it may work in the Amana refrigerator. It's just a switch that carries the current for the light bulb.
Dec 22, 2010 | Maytag Refrigerator Door Light Switch...
I need to defrost every couple of weeks
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Amana DRS2462B Side by Side Refrigerator
Amana drs246rbw - The water and ice dispensers will not work, the dispenser light will not turn on. The auger will work but ice will not fall through the opening. None of the green indicator lights will...
Your most likely culprit (since you still are able to get the auger to work) is probably the dispenser control board.
Also just double check the connections at the top of the freezer door under your hinge cover to make sure nothing came loose.
Jun 12, 2010 | Amana DRS2462B Side by Side Refrigerator
Evap fan not running changed and still not running
Good day,
On some Amana models the evap fan motor runs thru the defrost thermostat. The purpose was to delay the fan restarting after a defrost cycle so it wouldn't blow warm air. If you can jump the defrost thermostat and the an runs, then changing the thermostat will solve your problem.
Other causes on Amana could be on older models the fan was run thru the fan/light switch. If it's a rocker type switch, it could be the problem.
Call the supply house where you bought the motor. Ask if the light switches are 2 or 4 terminal. Both the freezer and fresh food switches. If they are 4 terminal, then they could be the problem, or they are not depressing far enough when the door closes.
Lastly, I have come across a few Amana's where they actually had a broken wire to the motor. In all my cases it was the white wire. The area where they broke, was not at the motor but further back in the harness. You would need a VOM meter to trace the wiring.
Jun 01, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Freezer works but fridge side not cold
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Dec 06, 2009 | Amana DRS2462B Side by Side Refrigerator
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
295 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
