Question about GE Refrigerators
No ice or water, new filter was working when installed
Model TFX25JPCG WW Replaced Culligan water filter ran over 1 gallon out to clear filter. Now no water or ice afraid some type of switch maybe preventing water from getting to ice maker or filter.
  • robkinsall May 24, 2009
    When filter was replaced it took a few seconds for ware to flow. 2 Minutes later it took a minute for water to flow, an hour later no ic no water
    Sergeant:
    Champion:
  • 212 Answers
Check filter again. clean area before installing. check water. check to make shure power is on.
Posted on May 24, 2009
Culligan AC-30 Howling Noise
yes you answered your questions there. i researched info and more than likely it is the valve
http://watersoftenernews.blogspot.com/2014/02/culligan-water-softener-noise.html
Oct 13, 2014 | Culligan RO Compatible AC30 Compatible...
WHERE IS OUR SOFT WATER!? A few years back we had the Culligan man out to check our water because it was not soft (at the time, we had the Culligan Mark 100 model). After testing our water, the suggested...
The most frequent causes for intermittent hard water would be the gallon settings set too low causing the softener to run out of capacity or a meter that is not measuring the gallons. I would set the "hardness" setting on your culligan softener 30% higher than actual hardness. The softening resins they use are low in crosslink and very inefficient. Also make sure there are no toilets leaking causing hard water to "bleed" through softener. Iron filters require regular maintenance to clear oxidized iron from nozzles and the valve. Generally it is better to have the iron filter regenerate at least every 3 days to keep the bed refreshed.
RJ
Mar 01, 2012 | Culligan Sediment Water Filter
I own an old Culligan RO system with a particulate filter, carbon filter, RO filter and post carbon filter all connected by tubes in an open environment. Replaced filters and tank is only 3-4 years old...
It is quite common to loose air pressure in the RO over time. At times the tank will be full of water but will not have enough air pressure to push water out. Take the tank of drain as much water as possible, for 3 gallon tank bring pressure in tank to 7psi, for 10 gallon tank pressure should be 10psi.
RJ
Mar 05, 2011 | Culligan Under Sink Water Filter
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
I'm looking for info on Culligan Super "S" water conditioner. Serial # V06244773 Part# 01014773 Can I get a manual? The water smells like rotten eggs. I need to know does it uptake bleach every 30 days or...
The Culligan Super S filtration system needs to have 1 gallon of 5% household bleach at least weekly. If your water is high in H2S it needs a gallon of bleach with every regeneration. Set the system to regenerate every day for 1 week and bleach at least 3x that week. Super S filters are recommended to be re-bedded every 750,000ppm. Regen cycle example: 2ppm iron, .5ppm H2S this system is set to regenerate every other and use 1 gallon of bleach per week. This system is now 13 years old and has exceeded the 750,000ppm suggested re-bed but is still performing with great water.
You also need to check the water heater to see if smell is coming from there. The anode rod in WH degrades and gives off a sulfur type smell. Here is a link for the Super S manual.
http://www.eculligan.com/support/supS-op-inst-manl-from1997.PDF
RJ
Jan 05, 2010 | Culligan Sediment Water Filter
Ice maker icing up
Sounds like you may have a couple of problems here. The frost build up could be from a bad door seal. Moist air can be drawn in and collect on the inside. As for the water temp, it sounds like the water line connected to the refrigerator could be tapped off a hot water line. It needs to be connected to a potible cold water line.
Aug 26, 2009 | Kenmore Freezers
Bad water & ice cube taste
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Particles floating in whirlpool filtered water.
okay - we have had this same problem for around 6 weeks - We called a service repairman to come out and he said that these "floaties" are harmless bacteria. We should disconnect the filter and flush the system by using 1 gallon of water a day (wasting it) after the chlorine in the water is allowed to build up again then the "floaties"- bacteria- will go away---- gross :-( We will see if it works---
Oct 16, 2007 | Refrigerators
Refrigerators Logo
162 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
