Question about Samsung DVD-VR325 DVD Recorder/VCR
Samsung dvd combo player.
Dvd player frozen. disc will not eject. power will not shut off.  timer signal keeps flashing.  It is frozen in the counter mode.
  • 1 more comment
  • baqs Nov 13, 2007
    the disc will not eject and keeps flashing 'on' and will not turn off
  • Gerri Hayes Oct 17, 2008
    My DVD will not open or eject: neither can I play the disc in it or a VCR tape. DVD player frozen. Even if I can no longer record; I would like to get the DVD to eject my disc. PLEASE HELP.
  • Anonymous Feb 16, 2009
    samsung dvd-v2000 will not eject disc
I had  the exact same thing just unplug & plug back in i guess it works like a restart button  hope this works for u 2
peace,
lexi
Posted on May 06, 2009
  • 4 Answers
Sell me your unit!
Posted on Jan 28, 2008
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
MAKE THIS TEST AND FIX IT. God bless you
1.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Oct 30, 2013 | Televison & Video
Technika 23" dvd combo DVD just shows no signal.
I also have this problem but the DVD will not eject.
Dec 27, 2011 | Televison & Video
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
Samsung dvd vr330 combo keeps trying to load a blank dvd-r
HI Not fixed yet but reading some of the answers that appear to be very common I am going to try a dvd cleaner on the machine so hope it works
thanks for tue info
crawfordj939
Jan 31, 2010 | Samsung DVD-VR330 VCR and DVD Recorder
The DVD player is in constant eject mode - discs will not stay in to play. It has worked perfectly for years. Tonight I was watching a disc, finished, ejected it and put in another and the player just...
Two possible scenarios: First the optical pick up assembly that read the disc has malfunctioned or the eject button is faulty. Either way it is just cheaper to replace the DVD player with a standalone dvd player connected to one the tv input(s). Too expensive to repair just the dvd player if it is tv/dvd combo. The cost for labor and parts is more expensive these days to repair tvs or dvd player. For around $30 you can just replace...much more cost effective.
Aug 15, 2009 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
Zenith XBV243 CD player keeps ejecting disk
You may need to try a cleaning disc to remove dust from the laser heads, as dust may be impeding the player from recognizing the disc type.  Also, double check the manual to see what disc formats your player can handle.  All players have a variety of formats they accept or reject.  If the owner's manual verifies that it does accept that CD format, try the cleaning.  If that doesn't work, it may an issue that will require an authorized service center to look at, which may not be work the cost as replacement DVD players are very inexpensive.  Avoid combo players such as the DVD/VCR combo, as when one quits performing, you either have to replace the entire unit or add a new single component for the bad one.  Hope this helps!
Dec 06, 2008 | Zenith XBV243 DVD Player/VCR
Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
Pre-recorded dvd won't eject/entire system frozen
Try unplugging the machine so it will reset itself. Then plug it back in. That has worked for me in the past.
pjrsop
Mar 24, 2008 | Samsung DVD-VR357
Samsung DVD-VR325 DVD Recorder/VCR Logo
319 people viewed this question
Jerry Greenberg
Jerry Greenberg
