Question about Thomson 30LCDB03B 30 in. HDTV
Thomson TV I have replaced a defective Vrt. Amp TDA8178F I.C. All in put Voltages are O.K. But there is only a Hor. Line. At pin no.1 I get about 500mV pp, saw tooth wave. Can some one be kind to advice me. ThanksNb:Model Thomson TV  55DF71 EX Suraweera
  • GloryMe Nov 15, 2007
    Please do anyone know where I can download a free service manual for Thomson RP52UK 52" or 50" Plasma TV. Problems with colour setting or may the convergence PCB. How to configure the combinations in the PCB.
    Your help will be appreciated.
    From GloryMe.
2 Suggested Answers
SOURCE: COD PIN FOR Tv-Thomson 21DC320, Tipe 507RG/ITC008
Sostituire la 24Wc08P con una nuova. Substitute 24WC08P with a new one. In this model it's very stressed and since it's a flash memory it has a limited number of writes. Ciao
Posted on Oct 01, 2010
My Panasonic TC-21Z88RBN doesn’t displays the total picture vertically ,when the picture is display it like not in the center of the screen sum of it is disappear in the bottom
Hello
Your TVs vertical output section has the fault. You just open your TV after disconnecting it from the AC mains wall socket, and locate the vertical output section. This section uses an Ic marked as part [IC 401] on the board and its number is LA7840. Just look for any loose soderings around its components legs, and the solderings at the IC legs, which has 7 of them. The IC stated above will be screwed onto a heatsink to radiate heat out of it when it works.
If all soldering point are fine, come towards the IC legs and measure the voltages at each leg. The voltages must be
pin 1= Ground
pin 2= 12.6
pin 3= 24.7
pin 4= 4.4
pin 5= 4.4
pin 6= 24v [vcc]
pin 7= 1.8
All voltages stated above are DC voltages with respect to ground. If any of this voltage is missing, find out the reason for that. If all of them are noted abnormal, IC may be defective, and replace it.
[vcc] stands for main input voltage to the IC.
If you need any more assistance, feel free to contact me through Fixya. Ok.
Dec 07, 2010 | Panasonic TC-21Z88R 21" TV
All I get is a narrow bright line across the tv
--- = faulty vertical circuit,could be a defect vert IC.
| = Hor circuit defect,could be a cap in the Hor circuit,mostly around 680n / 250V.
Aug 21, 2009 | Philips 27PT543S 27" TV
Set only has a thin line across,but sound is still there Is this something that I can repair myself ? I dont know much... 1 Solution
This is a problem with the vertical circuit. It can be as simple as poor solder connections at the vertical IC or a defective IC. Look for a small flat IC attached to a heatsink with about 11 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that does not resolve the problem, replace the IC. Please note that there are potentially dangerous high voltages present inside the set even when unplugged.
Keep us posted as there may be other components that need to be replaced. If so, the symptoms will change. Report them here and we'll provide additional details.
Thanks,
Dan
Feb 23, 2009 | Mitsubishi CS-35405 TV
Model CF1926A TV with insufficient vertical height. I replaced c308, c305, c301, c315. voltage was missing from ic501, pin 29; restored with replacement of c301. no help to vertical. voltage was missing...
I think you missed one cap. Look for another 1ufd cap close to the jungle chip. It will have the circuit designation in the 300's like the others in the vertical circuit. It is just not located close by. I think that one will fix it.I don't have the service data with me so I can't give you the exact designation.
Dan
Jun 04, 2008 | Toshiba Televison & Video
Sony tv no picture only horizontal line
The probable defective part is the vertical IC. If changing that does not resolve the problem, check the capacitors in the same circuit. Also, check for the proper voltages at the vertical IC. If the IC is not being fed its power, it won't work either. I don't have a listing for your specific model. If you can post the vertical IC part number (LA7837 for example), I can list the voltages per pin.
Dan
Apr 09, 2008 | Televison & Video
Loud pop and picture is no longer available.....
blown resistor (42ohm) replaced this and it imediately blew it clearly shows that there is a short circuit in your tv. if you are a tech person please proceed as follows. 1 isolate power supply from hor.output section. 2 now check power supply section.i.e. switching tran., cap..diode etc. 3 if it becomes ok check power supply output. 4 if output is ok then check hor. output section.i.e. h.out tr.,cap& diode in eht winding. 5 check print near eht. 6 at finally eht. 7 see every thing is normal now. now reconnect power to hor.section. put on tv. good luck.
Sep 24, 2007 | Philips 7P6041W TV
JVC TV- MODEL AV-K21T.
it was not necessry to replace so many parts if you go as per proper procedure.please proceed as 1 isolate horizontal output section from power supply & make power supply ok. 2 if it becomes ok check hor osc,driver&h/output section. 3 if it is ok connect power input to hor.section which was isolated. 4 check for loose contact or print. 5 put on tv .
Sep 22, 2007 | Televison & Video
Ticking sound
ticking sound (like a Watch) coming from around the Flyback Transformer but I don't see a spark is called EHT voltage . if eht voltage is ok 1 check filament is glowing or not if it is ok check voltages on crt. 2 if it is ok check luminance section in chroma section. if filament is not glowing check for low eht due to hor section check power supply output also. good luck
Sep 18, 2007 | GE 25GT270 TV
55 in Sony KDF55WF655 Goes to standby and red light blinks 4 times
Check the thermal sensor fuse part# 1-910-023-93 or possibly one of the four fans. If the unit goes into Fan/Thermal Protect shutdown (4 blinks) it can be difficult to determine the cause since the unit turns off too quickly to troubleshoot. Solution: Ground the data line by inserting a jumper between pins 3 and 6 of CN44 on the H4 board. This overrides the protection circuits for troubleshooting. Do this right after turning the unit on and as soon as the lamp is seen lighting. Check pins 2, 5, 8, and 11 of CN6000 on the G2 board for less than 1VDC. Any voltage higher than that indicates a faulty fan. If all voltages are within specs, the H4 board must be replaced. If a fan is found defective, the optical block will need to be replaced if it is located inside the assembly. H4 Board Part Number: A1054674A Replace the following part based on which pin of CN6000 is out of specs: Pin 2: Fan 1 (part of optical block) Pin 5: Fan 2 178723211 Pin 8: Fan 3 178706511 Pin 11: Fan 4 178708111 Optical block Part Number: A1084662A
Aug 26, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
JVC C-21MU1 / High Voltage Problem
Try checking the filter in the 116v line. You may have an intermittent spike coming through the B+ line.(The filter may have decreased in value) Also a small filter in the X-ray circuit could have lost capacitance. There is a low value capacitor (about .047uf @400v) in the collector circuit of the horizontal output transistor that will detune the horizontal circuit causing the HV to go too high. If this cap is intermittent it may be causing your problem. Stargazer Hope this helps
Aug 25, 2007 | JVC AV-28-BD-5-Bl 28" TV
Thomson 30LCDB03B 30 in. HDTV Logo
134 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
