Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Turn the key to start, all I get is a click, starter won't turn
Intermittin problem since we got the zforce mower.
  • 376 Answers
Sounds to me like a defective solenoid, especially if it will finally start after numerous times turning ign. switch to start.
Posted on May 24, 2009
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Craftsman Tractor solenoid clicks but won't start
could be a safety switch or a ground problem check the ground for corrosion and make sure it is tight at all places then check each safety switch they usually have one for the seat,mower deck and clutch/brake pedal
Jun 19, 2013 | Garden
Have 17 half briggs&stratton engine go to start it turns half trun and stops turn key on and off won,t turn just clicks take plug out turns good
first thing to check would be the flywheel key. if it sheared then the mower could be sparking at the wrong time keeping the engine from being able to turn over
Mar 02, 2013 | Garden
My Yard Riding Lawn Mower won't start when I turn the key on it just clicks
Click means solenoid has enough battery power but maybe not enough battery power for the armature of the starter to spin, it may be low battery or bad solenoid contact - inside it, (copper washer and pin), or thirdly it may be the engine is stuck so try to turn it a bit by hand to rule this out. Turning the engine a bit by hand may also free a starter gear that has jammed on the flywheel teeth.
Jun 30, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a cub cadet zforce 48 zero turn. It wont start unless I jump across the solinoid. I've changed it and still does the same. Whats the problem?
Make sure the control arms are all the way out, the brake is locked in the on position. There are safety switches on each control arm and one on the brake lever, also there is a safety switch on the seat...if either is faulty the mower will not key start.
Apr 21, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
363 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
