Question about Dell Dimension 8400 PC Desktop
Cant access internet without network adapter operating
I just reinstalled OS now all it shows on ethernet adapter is a yellow ? and other yellow ? in theother devices. also the modem shows "connection between 2 comuters cale" i cant acces the internet to update the drivers tho what can i do
  • Tina Frucci-Moore May 24, 2009
    i do not have the original CD but i do have an ultimate driver CD i got from a friend only problem is ,is that there is a lot of stuff on it and i cant tell what i need from it.. would it be just as easy to go purchase a new network ethernet adapter and put it in?
    Novelist:
  • 142 Answers
You can download drivers at
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8400&os=WW1&osl=en&catid=&impid=
If internet is not working , then u might have received a CD with when u first got ur system, it has all the drivers that ur looking for.
If u cant find the CD, then contact Dell Technical support, they will send u one free of cost.
Posted on May 24, 2009
Dell dimension 1100 DE051 Internet drivers are installed All connected successfully Internet will not work Please help
Check that all drivers are installed and working in device manager as when I reinstalled Windows not all of the drivers installed and I had to do it manually. These drivers were the ones that give you access to the internet. These were network adapters and IDE ATA /ATAPI controllers.
Hope this helps.
Aug 14, 2014 | Computers & Internet
I reinstalled windows xp on my hp dc7600 small form desktop unfortunately i have lost my network adapter driver so i cannot access the internet to fix this problem however i do have accesss to another...
You will have to open up your network connections. Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled. Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question / Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device You only need check the following if you cant install the driver Make sure you Ethernet/internet is enabled in bios. Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press Enter make sure its enabled then recheck the driveri t should be there k the driver it should be there make sure its enabledPci device arrows key scroll to nstalled if you computer came with a motherboard disk the driver could be on it or this disk provided by your ISP provider Internet Service Provider or you might have to download one http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Mar 03, 2013 | HP Compaq dc7600 Convertible Minitower PC...
Hi, when i tried to connect to the internet, it shows "OS error,may be the modem on your remote computer is out of version please solve my problem
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jun 11, 2011 | Dell 210W Optiplex GX270 NPS-210 AB Power...
I re formatted hardrive. reinstalled O/S. cannot connect to internet. device manager shows yellow question mark over ethernet controller, multimedia audio controller, video controller. has error message:...
What kind of computer do you have? The trick here is first to get the computer on the internet by finding out what kind of network card is installed on a internet connected computer do one of the following
1> If its a dell go to http://www.dell.com/support and click on download drivers enter your service tag number Download the network driver to a flash drive and install Connect to the internet and repeat the above process to install the other drivers.
Most manufacture websites will have a download page for the drivers but you can also google the make model and operating system drivers for example google acer aspire 1000 xp network driver.
if you post your make model and operating system I can help you better.
Aug 04, 2010 | Dell Ethernet Card Network Adapter
My router won't link up to my modem. I have a
make sure that you ethernet adapter is enabled. you should be seeing a two computer icon in the notification area. reinstall driver of your eternet adapter.
Apr 01, 2010 | Powerline Ethernet Network Adapter
Ethernet controller and USB are missing on XP
Yes, the device-drivers can be downloaded from the Internet, to one computer, and then burned onto a CD-writable, or written to a USB memory-stick, and then the files can be physically moved to the other computer.
But, "which" device-drivers is completely dependent on which computer that you have. Some motherboards have "integrated" network-adapters and "integrated" USB-ports.
Easiest solution is to take an add-in PCI network-adapter card, and install it, and connect the Ethernet cable to its socket.
Hopefully, Windows will recognize that card, and automatically load the correct device-drivers from the C: drive, i.e., without Internet access.
Or, if you buy an add-in card, it may come with a CD-ROM that contains the device-driver.
Once the device-drivers have been installed, you will have Internet connectivity. Access: http://WindowsUpdate.Microsoft.com
and click "Custom" scan, and then click "Optional Hardware".
Windows Update should find the device-drivers for your motherboard, and install them. Then, you can remove the add-in card, and connect the Ethernet cable to the "on-mother-board" network socket.
Dec 14, 2009 | Microsoft Windows XP Professional
I reinstalled Windows XP to my computer and now i cant get the internet. There is a yellow question mark and exlmation point next to Ethernet Controller and it has a code 28 error.
You should have had 2 cds that came with your computer. The 2nd one has all the drivers on it. Install the drivers and your problem will go away.
Nov 19, 2009 | Microsoft Windows XP Professional
Ethernet not working after format and xp reinstall
Right-click the My Computer icon and select Manage, then go to the Device Manager in the list on the left and find the Network Adapter from the list on the right, right-click Network Adapter and select Uninstall. When you reboot, XP should find the Adapter and reinstall it automatically. Another reboot may be required.
If it still will not connect, go to the NIC Manufacturer's website and download the driver to removable media. The Driver Update option can be accessed in the Device Manager, but this time select Properties when you right-click the Network Adapter, and go to the Driver tab.
Dec 22, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Ethernet controller with big yellow question mark
You need to reinstall the software for that, if its a ethernet card built in to your motherboard you can find the software for it from the motherboard setup CD , and if its a additional device to your computer just run the setup CD for it to reinstall the software back....
Sep 12, 2008 | ASUS PCI-L3C920 Network Adapter
Corrupted network drivers
what OS are you running,
Try removing it and reinstall
if it persists then try another card
update drivers and this should fix the problem
another thing also worth thinking about....
Maybe time to consider formatting the system and reloading it again with a fresh install.
Aug 02, 2008 | Zonet Fast Ethernet Adapter Realtek 8139D...
Dell Dimension 8400 PC Desktop Logo
Alun Cox
