Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Ice is made but dispenser does not spin so ice wont drop
I just bought a 4yr old used fridge. it has an ice & water dispenser. I watched it work when i bought it but when i got it home, the water worked & the icemaker made ice but it will not dispense ice. when i push for ice, i can hear something quetly humming but no ice drops down. is there something i was supposed to do during set up?
    President:
  • 1,136 Answers
Hi, Remove the ice bin. With the freezer door open, push the door button and then push the ice dispener button to see if the auger motor is turning. If it does turn, check and see if there is something in the ice bn blocking the auger.
Please try this and let me knwo.
Thanks
Vic
Posted on May 24, 2009
Why water to icemaker , none to water dispenser , replaced water inlet valve fghs2655pf1 or 4a32520097
Refrigerator Not Making Ice? Water Inlet Valve Test - Fridge ...
? 2:47
https://www.youtube.com/watch?v=aXIX73EI1Z4
May 15, 2012 - Uploaded by RepairClinic.com
This video demonstrates how to test a water inlet valve on a refrigerator. ... Ice maker or water dispenser not ...
Refrigerator Ice And Water Dispenser Not Working - Repair ...
www.repairclinic.com/...---/Refrigerator-ice-and-water-dispenser-not-wo...
How It Works: Refrigerators · How It Works: Refrigerator Icemakers · How It Works: ... Most Frequent Causes for Refrigerator ice and water dispenser not working.
Nov 18, 2015 | Refrigerators
Why is the water running directly into the ice dispenser and running out of the door when we are not pushing the lever to get water?
Sounds like the water valve is stuck or the wiring or switch is defective. As both ice and water are a problem it sounds more like a defective water valve.
Oct 05, 2014 | Whirlpool Refrigerators
The water dispenser is not putting out water and ice maker is not making ice. The fridge frequently cycles like it is trying to send out water.
it's still under warranty for up to 1 year,call whoever you bought it from and it should be repaired free of charge and next time you write send model number.
Dec 08, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Aug 09, 2009 | GE Refrigerators
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Icemaker isn't making any ice
Your fill tube that fills the Icemaker could be froze up, The plastic tube that goes into the icemaker. Sometimes they get froze shut. You can remove it from the back of the fridge, just pull it out from the back and take a look. If that doesn't work, Let me know.
Bill
Apr 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Stainless Steel side by side fridge GS425JSRF - 2 ys old
Make sure there is no obstructions from the time the ice leaves the chute until it drops into the glass. make sure the motor that moves ice and out to the area for the cup is stuck or seized up let us know thanks
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
247 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
