FixYa.com
Tags:
Epson 5300 7200 7300 Replacement Lamp - ELPLP05 Projector Lamp
No power
posted by gdady on Oct 20, 2007
i have an elp 7200 it was a gift there is no response when i try to power on
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 18, 2008
Not Rated (0)
marsrover
Rank:Wiz Wiz
Rating: 80%, 145 votes
1-check power from wall outlet.-test with another equipment.
2-change power cord-and test.
3-apply contact cleaner in power switch(from radio shack).
4-check for blown power fuse.and change with same rate if it is blown.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Multimedia Projector Replacement Lamps problems?
Continuity test for a projector...
Can I use an ohm meter to test... Answer This...
invert image on projector
i have a generic chinese... Answer This...
magnavox replacement remote...
a some where to purchase one in... Answer This...
serial port
a serial port was broken off... Answer This...
image is flickering
The ?flickering? of the... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
