Question about Bose Lifestyle 48 System
Bose Lifestyle 48 System play's dvd in black & white only also connect to vs-2 video enhacer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
This sounds like a loose s-video cable at the back of the media center (connecting from the VS-2). Check that connection.
If adjusting this cable does not fix this (I'd be surprised) then just reset your media center by unplugging the dc power cable for about a minute and plugging it in again. (while system is off first of course)
Posted on Jun 01, 2009
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
VS 2 not found
Try unplugging both the main console (lifestyle) as well as the power to the vs-2. (IT's the black cord). You have to wait 30 - 60s. This worked for me after also making sure the video was set to "NTSC Progressive" (you can do that by turning the bose off, holding down enter, and then pressing store twice till you get to "video". Then use the volume arrows to select NTSC Progressive.)
Nov 16, 2009 | Bose Lifestyle 48 System
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Jun 14, 2009 | Bose Lifestyle 48 Series III System
Hello,I have a Bose Lifestyle
If you use both s-video and composite (yellow) video at the same time on the bose system, it thinks you want to use the component adapter (which is included with the system). Just use one or the other. But if this is still in black and white (it may because the system still thinks you're using the adapter) just press "system" on the bose remote, and go to "video" and then "video connector" If video connector says "Component", try to change this to "composite + s". If this doesn't let you change it (it may not) then restart the system by unplugging the DC power cable for 30 seconds and re-connect it. I hope this helps.
Jun 01, 2009 | Bose Lifestyle 48 System
Bose Lifestyle 48 System play's dvd in black & white only also connect to vs-2 video enhacer hello, my bose lifestyle 48 only plays DVD's in black and white. I can't find a setting or a reason why it...
Your s-video cable at the back of your media center is loose. This will cause black and white internal video and is known to fall out or just become loose from minor movement. (it's the nature of s-video cables) This should solve your problem. This is the s-video cable that connects to the VS2 and media center.
If this doesn't solve the problem (I'd be surprised), just reset it by unplugging the DC power cable at the side of the VS-2 for about 30+ seconds and plug it back in..
May 31, 2009 | Bose Lifestyle 48 System
Black and White instead of color
Assuming you are using the VS-2 with your system. I have experienced the same problem when I fiddle with equipment. Each time it is due to the S-video plug from the VS-2 cable becoming loose or detached. Make sure every cord is re-inserted into the back of the LS 38.
Dec 07, 2008 | Bose Lifestyle 48 System
Bose lifestyle DVD only playing black and white.
We had the same issue. The svideo cable was no longer connected. It had become unconnected when we were connecting a game system.
Dec 06, 2008 | Bose Lifestyle 28 System
DVD problem - now only plays in black and white
Check the video connections on the back of the Bose unit. I have a Lifestyle 38 and had an issue with video only playing in black & white. Turned out to be a loose connection.
Nov 10, 2007 | Bose 3 2 1 GSX System
Bose Lifestyle 48 System Logo
329 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
