Question about Spectroniq PLTV3250 32 in. LCD TV
Not even 2 years old and no power
All of a sudden tv won't turn on and no red light on tv. tested power cord with electrical test and shows good. service number in booklet no good nor is www.spectroniq.com sight any good. does anyone have any suggestions? I turned off my pltv3250 last night when I woke this morning I had no power to the unit I changed outlets and got the same result no led's were lit on the unit tried calling customer service no response
  • vanderhiede May 24, 2009
    no power to tv worked fine lsat night when shut off woke this morning tried to turn on and there was no power to the tv tried different power source still no power or led's lit on front of panel
    Brigadier General:
  • 3,614 Answers
HI there,
this can be a problem on the powerboard area, a busted or a faulty fuse or capcitor need to be test and replace, better call a local repairman on your area to check the tv.
let me know
Posted on May 24, 2009
  • 432 Answers
Have you checked the mains cable to make sure that the fuse has not blown ?
If it has ensure you replace it with the same wattage fuse and try again.
If that does not work or help then there is obviously something wrong with the TV - if its under warranty then get it repaired under that otherwise take it to a TV repair place and they should be able to repair it for you at a reasonable price.
My sceptre has no power. The red light doesnt come on. could it be the power cord.
I am afraid the power supply has gone bad. but look for damage on the cord, and do a wiggle test on cord as you try to turn tv on.
press the helpful button and follow me on fixya for more tips
Jan 28, 2016 | Sceptre Televison & Video
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
My name is shakena brown, i have a sanyo 32in flatscreen TV that I brought from Wal-Mart. The TV is not an year old yet and it will not show anything. When I plugin the cord in and turn the TV on the...
Your set is still under a manufacturer warranty. Take your set back to Wal-Mart and they will send it out to be repaired, or give you a new one.
May 19, 2011 | Sanyo Televison & Video
Even when laptop is plugged into an electrical outlet, it will suddenly think it is not and drain the battery power..the indicator lights will flash and battery power will drain.
There may be a fault in the laptop's power supply adapter.
Try testing its rated output voltage versus the actual with a multimeter.
If the adapter comes in 2 sections, 1 cord from the wall to the adapter, and then the adapter to the laptop, be sure to test both sections.
Replace the adapter if required.
Also check that the connection socket where the power adapter plugs into the laptop is not loose and preventing proper electrical contact.
Good luck.
Feb 28, 2011 | 4D NSpire Power Supply NSP-300P4D 300W...
I was watching a dvd on my week-old Sony Bravia XBR-52HX909 for the past three hours when the screen suddenly went blank. The standby indicator light in red started blinking. I attempted to turn on the...
This tv only a week olds,should never having this problems already.The tv should be return and get a new tv for the replacement,this tv have tv Tuner signal board or tv power supply board distrubution problems.Even when the store test it out it work,don't take that tv back.Insit they give a new tv for the replacement.
Dec 13, 2010 | Sony Bravia XBR-52HX909 52 in. LCD HDTV
Brake Box Will Not Work
First try a 12 volt "stab in" test light pushed into the blue wire at the brake controller. Red is brake feed from the truck, black is 12 volt power and white is ground. If all is wired correctly, the blue wire should power up when you hit the brakes. Be sure to turn the controller up to highest setting to test it. When you hook the test light up, the connection indication light should come on. Then turn red when you hit the brakes. Also see http://www.etrailer.com/faq-wiring.aspx for more info.
Oct 22, 2009 | Pioneer Voyager 4000 HD-DVR
DVD not showing a clear picture
test test test 17:05
danke bitte
do not answer test test
sorry
Jul 04, 2009 | Televison & Video
No power all of a sudden.
Most likely your power cable not working. check the cords for bare wiring (if any metal is hanging out of the rubber insulator). If it is bare then go and get another cord. That should work.
Jan 29, 2009 | Olevia Televison & Video
no red light on tv. no power only two year old, need help.
Oct 30, 2008 | Spectroniq Protron PLTV-32 32 in. Plasma...
Spectroniq PLTV3250 32 in. LCD TV Logo
56 people viewed this question
Top Spectroniq Televison & Video Experts
Frank Zabroski
Frank Zabroski
Jayesh Panchal
Jayesh Panchal
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
