Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Error code f-05
Washing stops and f-05 appears on screen
  • 157 Answers
Pump
Posted on Jun 02, 2009
5 Suggested Answers
WhIzAtIt
  • 136 Answers
SOURCE: error code f 05
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump. The fault is associated with drain out (pump blocked or restricted in some way). Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Posted on Sep 17, 2007
Great advice. That sorted the problem. And it made me £2.05 !!!
Yeah just undo the big jubilee clip, pull the big black hose down, take out whatever's blocking it, put the hose back on...and voila!!!
Thanks Gigwiggin...topman.
Posted on May 17, 2008
SOURCE: Error code F05 after the start of wash cycle
error code F05 after the start of wash cycle, what do i do now
Posted on May 24, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Posted on Jan 10, 2010
Error code f-05 on idesit wixe127
F05: Pump Blocked or pressure switch empty not reached
- Check efficiency of J9 connector on card, verifying a voltage of 220V between pins 8 and 9
- Check that pump if being fed
- Check Pump Filter + wall drain
- Change Pump
- Replace Card
Dado
Feb 28, 2015 | Indesit Washing Machines
Machine reading F63
I hope a way to delete this code from the screen
I waited for 20 minutes and stopped flashing screen
Will not disappear
Press any buttons after the screen has stopped flashing
Jun 20, 2011 | Washing Machines
Error code 05 appeared on screen. We have tried to reset. Hit stop, enter, & quickstart buttons as decscribed. We also tried the reset button. The error code remains. We unplugged and tried again, but...
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Apr 11, 2011 | Precor 933 Premium Series Treadmill
Washing Machine Aquarious Ultima the screen shows F 05 ? it does not finish washing and the door can not be opened
Hello there:
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Dec 26, 2010 | Washing Machines
Hotpoint ultima F-05 errorr appears on machine
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
F-05 flashing on the display screen
Hi There
I have this for to read and hope this helps out. Let me know how this works out.
Thank you for writing to fix ya.
Best Regards Richard
Dec 28, 2009 | Washing Machines
Iomega Screen Play HD showing fatal error 05 -
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Sep 25, 2009 | Iomega ScreenPlay
F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
My washer is saying F-05
Error code F05 is indicating that the pressure switch is jammed on full.
Make sure pump is working o/k and that washer is draining properly. Check filter.
If after doing all these checks and error reappears, then I would suggest you call an engineer.
Plz rate my solution.
Thanks
Jan 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
207 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
