Question about Microsoft Windows? Vista Home Premium Edition Upgrade Version for PC (1 Computers) (66I-00021)
Cannot remove yoog
Yoog just mysteriously popped up over night. Running Vista
    President:
  • 948 Answers
Instructions for removing Yoog are here. Please rate this solution a FixYa.
Posted on May 24, 2009
What makes the push-rods come out from under the valve tappets in the morning after it has set all night? The rods fall down, therefore, it will not start.
I would check to see if the valves are sticking or if you have very weak valve springs. Can you get some penetrating oil on the valve stems whil cranking the engine? I would also condider running a product like Marvel Mystery Oil in the intake while it is running and addin some to the crankcase oil. Let us know if this helps..Robert
Mar 27, 2013 | Denso 2001 Ford Ranger Edge 3.0L...
02 Quest odometer is working but has no light to see it at night.
The display needs to be removed and sent out for repair. There are many online repair sites that can fix Nissan instrument clusters. Find one and contact them for pricing info and removal and shipping information.
Apr 04, 2017 | 2002 Nissan Quest
Mysterious light on dash??
You know what the real mystery is here? WHAT THE MAKE, MODEL AND YEAR OF THIS VEHICLE IS????
Mar 21, 2012 | Cars & Trucks
Running Vista, Pop up window,
Click computer, then right click on the D drive. Select properties and format the drive.
Jul 27, 2010 | Dell Inspiron 530 -Intel® Pentium®...
My LaPazz WP8060 is not working!!
have you tried it in any other versiin of windows such as 7...
maybe the drivers are not for vista... if tha doesn't solve it then must be hardware issue
Apr 18, 2017 | UC-Logic WP8060U (689076313025)
Yoog Search engine removal
i completley removed firefox as I got rid of the yoog problem on IE8 and it kept reappearing on firefox and then back onto my IE8.
To remove 'yoog', reset your default search at the top right to google. on START at the bottom left, type in COMMAND PROMPT. on the black screen on command prompt, type in REGEDIT. This will take you to the regestry editor, go to EDIT then type in YOOG on find........... 3 codes will appear. Right click DELETE each one. Restart your computer.......... Problem solved.
Jan 09, 2009 | Computers & Internet
Possable Engine Seize
Use Marvel Mystery Oil, it will loosen the rust that you may have incurred while the bike was sitting. Just one word of caution, if the mystery oil does get the pistons free I doubt seriously that you will have any significant ring seal left. You may be better off removing the heads to see if there is serious damage. You can easily bend a rod if you are not careful and it's not worth destroying the engine because of the rust issue.
What most likely has happened is your cylinders suffered from condensation which will promote the rust. The pistons will not rust, (they are aluminum), but the rings and the cylinder walls will. You may need to simply remove the pistons and run a quick hone through the cylinders, put new rings in and be good to go.
By no means should you attempt to push start it or anything remotely close. You can take a wrench and try turning the motor over by wrenching on the end of the crankshaft where the electrical stator is. A small amount of rust will stop the starter motor from turning the motor over.
Let the Marvel Mystery Oil soak over night before trying anything like turning the motor over. You may be very surprised and lucky if it works.
Best of luck to you.
Dec 08, 2008 | 1991 Honda ST 1100 Pan European
Pop ups, infections, viruses ,worms
If you have Vista, try running Windows Defender within Vista. If that does not work, Spysweeper will get it.
Jun 06, 2008 | Toshiba Satellite A135-S4527 Notebook
Microsoft Windows? Vista Home Premium Edition Upgrade Version for PC (1 Computers) (66I-00021) Logo
91 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
