Question about HP LaserJet 1320 Printer
HP LaserJet 1320 folds over top left corner of every page printed
The paper is loaded in the automatic feed tray. There are no other problems.
  • 21 Answers
I see this problem alot after a paper jam occurs and someone has pulled the stuck paper out. There is probably a piece of paper stuck in the printer somwhere. If you open the front toner door and take the cartridge out, you will see a roller at the bottom front. DON"T touch the roller but take it out. You may find the paper there!
Posted on May 26, 2009
Paper Feed problem
I think its logic board related problem.
have a technician look onto it...
Nov 08, 2013 | HP LaserJet 1320 Printer
When i trunn on and when i want print all ways stuck
if you see brown marks on the center top of your page then its your feed roller... hp feed rollers come out easy... Get some rubbing alcohol or hand sanitizer solution and clean with a paper towel... Make sure to dry your feed rollers then put them back in... that should clear up your issue... if that still does not work you may need to replace feed rollers
HP LASERJET 1320 FEED ROLLERS TRAY 2
If it feeds ok but gets stuck at the back then chances are your fuser is bad. The belt is most likely ripped.
HP LASERJET 1320 FUSER ASSEMBLY
Sep 12, 2012 | HPLASERJET1320N LASER Printer INTEGRATED...
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
Left corner is folded down on page
Sounds like an issue with the feed rollers. The roller on the left side might be hung up and is causing the corner to fold over when the paper is pulled through. I would try checking the feed rollers in either the actual tray or the back of the printer. Another thing to check is the other tray (the manual one). Does the paper fold? this should help you narrow down where the problem lies.
Mar 02, 2011 | HP LaserJet 4350 Printer
1320 Printer prints with corner fold
This tells me something is getting caught usually I would recheck the Paper Tray. If possible you could run the paper through the Bypass or Tray One as HP would call it. See if it is happening there if so then you can eliminate the Cassette Trayi
Also Did you run any lables through this Printer ??
Sep 12, 2009 | HP LaserJet 1320 Printer
Hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Jun 18, 2009 | HP LaserJet 1320 Printer
Problem feeding paper in JaserJet 1320
Remove toner and cassette.
Turn the machine upside down .
The feed roller should not freewheel, one of the tabs could be broken off of the feed roller.
Feb 05, 2009 | HP LaserJet 1320 Printer
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
Load Noises
If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
If the noise does not recur with the print cartridge removed, replace the print cartridge.
If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at
http://www.hp.com/support .
Feb 15, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
306 people viewed this question
Seeker5211
Seeker5211
