I install bios update and now mi notbook gateway mc7321u is not runing windows,,,, only turns on the leds
Not Good Juen: If a computer is running ok, never mess with the BIOs as they are critical to the booting of the system. Any interruption during the Update will mess up the instruction sets and cause the computer to go into limo. A responsible technician can overcome the problem, but I doubt if you have the skills to do a fix.
Testimonial: "yes i can fix it,,, but what can i do"
yes i have the skills to do a fix,,, but give me some tips,,,,i have mi pc all ready all opened
Are we looking at a PC or a Laptop?
Laptops are difficult because the Bios are sometimes integrated onto the main board. If they cannot be removed and replaced, we have a serious problem?
If it is a PC, just remove the button battery, dischage the memory and try to reboot. PCs have BIOS that can be removed and replaced as a rule.
ok but is there a posibility to boot bios in cd or usb? or husing some keys when just start up de pc,,,, like windows key and b,,, or esc and b or some thing like that???
ist a noote book pc
its a laptop
SOURCE: my gateway nx560x needs the bios updated and
hello, your model of laptop (NX560X) is able to boot of the usb port, what that means is even if you don't have the laptop working, and don't have a floppy drive, you can use USB flash drive, usb floppy etc to boot up the laptop from.
you should use other PC (perhaps the one you are using to post here :-)) to download bios from gateway website and then use usb device to boot your laptop. Below is the direct link for your laptop and here you will find latest firmware and drivers;
http://support.gateway.com/support/drivers/search.asp?st=pn¶m=1008644
After you are able to flash the BIOS, test to see if the you can get into windows.
post back your results so we can further troubleshoot the issue.
hope this helps
regards
Amar Sondhi
SOURCE: dual monitor for gateway mc7321u
FIRST YOU NEED ANOTHER VIDEO CARD TO PLUG YOUR SECOND MONITOR.WHEN YOU GET AND INSTALL THE NEW CARD POWER ON THE PC AND THE OS WILL DETECT IT.
