Question about Panasonic NV-MX500B Mini DV Digital Camcorder
Panasonic NV-MX 500 no aqspect
In the menu-camera setup - aspect there is only 4:3 in blue color
and I can't ger the 16:9 mode
the rocord mode is normal in blaue as well as the D-zoom off
Hi, I have the same model. I think that if you have selected one of the options in the menu to CINEMA mode, then the 16:9 aspect ratio becomes unavailable. Try taking it off this and see if the 16:9 option is avaialble.
Posted on Jun 11, 2009
How do you change the stills function from 4.3 to 16.9 its really not very clear?
Hi
Having looked at the full manual - downloaded from here and savable:
http://tda.panasonic-europe-service.com/docs/2z54662404z3z38916z656ez706466z22zdf06e277f71e6367f9e09db70241478cb0ad23ae/tsn3/data/ALL/HXWA30EG/OI/902781/vqt4x32.pdf
I think you will find that you cannot actually change from 4:3 to 16:9 aspect ratio for a particular pixel sized picture. When you set the pixels for the picture you want, the aspect ratio is set automatically.
For example:
16Megapixels 4608x3456 4:3
12Megapixels 4608x2592 16:9
See page 96 of the manual mentioned above for a full table of Megapixels, size, ratio etc
Therefore changing the picture size from the simple menu changes the aspect ratio but you do not have control of the aspect ratio for each size, in other words you cannot take a 16Megapixel picture at 16:9, it has to be 4:3.
Hope this has been helpful
Cheers
Nov 14, 2014 | Panasonic HX-WA30EB-K Hx-wa30 Upright...
Panasonic lumix dmc-zs3 display colors not showing
We recommend you enter the camera's menu and try using the reset procedure, in the setup menu, available here: http://service.us.panasonic.com/OPERMANPDF/DMCZS1.PDF#page=24
Mar 25, 2014 | Panasonic Lumix DMC-ZS3 Digital Camera
Hi. We have a Sony dvd player dvp-sr200p and have a wide screen tv, when we play a dvd we get a small square picture with black sides. We would like the have a full picture like we had before. Could...
With the player in STOP mode, or without a disc inserted, press DISPLAY on the remote. Then press either the UP or DOWN arrow keys (on remote) to scroll down from LANGUAGE setup to SCREEN SETUP, then highlight the aspect ratio which best suits the connected TV, in this case 16:9 widescreen (according to the manual the default aspect is 4:3 letterbox). Once you have made the change, exit the setup. It should remember the setting you have made.
Pages 26 to 27 of the owner's manual illustrate the setup procedure for this model DVD player.
NOTE: some DVDs may be encoded as 4:3 titles, hence you will see black borders at the left and right sides of a widescreen TV. Not all DVD movies are encoded in the 16:9 aspect ratio.
However, you can check your player's setup menu just to be sure.
Apr 08, 2011 | Sony DVP-SR200P DVD Player
I purchased a DVD that states: Widescreen Format (Aspect Ratio 1.85.1) I'm unable to get 'widescreen/letterbox'. The movie shows up full screen or a 'stretched' view. All other movies I've...
On the DVD recorder remote: press function menu button: enter setup screen - scroll down to connection - TV aspect - select either 16:9 / 4:3 Letterbox / 4:3 Pan&scan. If you are using an older TV which is not a widescreen, set the aspect to '4:3 Letterbox'.
You should now be able to view your DVD movies from this machine through a 4:3 standard TV in letterbox format. (some DVDs do not allow pan&scan so letterbox or widescreen is recommended). Very rare that a DVD title is not compatible with 4:3 TVs. I assume your deck is set to output 16:9 aspect by default.
I find this is the cheapest and easiest solution and can save lots of dollars in service call-outs. You can always reset the unit back to shipping condition later if you need to, or in the rare case of digital channels disappearing from your tuner memory.
Jan 09, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Video recorded on nv-gx7 in cinema format wish to convert it to 4:3 aspect ratio
You can use a software called VideoStudio Pro X3 to convert it,but if you can't record directly at the Panasonic Video camera.
Nov 22, 2010 | Panasonic HDCSD60 Video Camera Flash Media...
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
Unit language
Download the driver from the site then in the help menu go to the language setup. You might have to guess your way around in this but refer to Panasonics other insturuction manuals you should know when you scroll to the english section. Also refered to as nv-gs50e or nv-gs70e. Go to http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-75489-Camcorders#Anchor_13 it will be the third driver from the BOTTOM. This model has been discontinued so support for later windows editions are not likely. Windows 2000 is the last version you can always run your compatabilty mode with 2000 for optimum preformance.
PAL Mini-DV Cameras/recorder
NV-GS50E
Dec 22, 2008 | Panasonic NV-GS50 Mini DV Digital...
Lumix fx 500
Vincenzo, ti scrivo in italiano, cosi non usiamo traduttore, a quanto dicono i manuali la macchina dovrebbe avere opzione linguaggio giu nel menu, prova a ricontrollare.
Riporto la risposta del mio ultimo commento :
"Guarda che se vai giu nel setup menu, quello con la chiave dameccanico, dovresti trovare il menu Language, che forse nella tuacamera e' in giapponese, da quanto ho capito.
Qui c'e il manuale in inglese piu completo.
A pagina 23 inizia a spigare il setup menu, a pagina 27 c'e' language.
Secondo il manuale le voci del setup menu iniziano con l'orologio e sono:
  1. Clock
  2. World time
  3. Monitor
  4. LCD
  5. beep
  6. volume
  7. guideline
  8. histiogram
  9. travel date
  10. economy
  11. auto review
  12. no reset
  13. reset
  14. usb mode
  15. Video out
  16. Tv aspect
  17. m/ft
  18. touch guide
  19. format
  20. Calibration
  21. Language
  22. Demo mode
al posto 21 c'e la faccina con qualcosa in giapponese.
Se non la trovi fammelo sapere."
Se nel modello giapponese non c'e' l'opzione linguaggio, allora sei nei guai, perche panasonic non ha ancora distribuito un update del firmware per questo modello, si trovano solo modelli precedenti.
Per quanto ho visto il firmware non e' disponibile online.
Puoi provare a richiederlo a panasonic, qui c'e la pagina dei contatti.
Ricontrolla e vedi se trovi il menu linguaggio, e' strano che non sia presente.
Questo e' il simbolo della faccina che indica il menu linguaggio: bba5910.gif
Oct 27, 2008 | Panasonic Lumix DMC-FX500 Digital Camera
Sanyo vpc 500
1. Turn the mode dial to "P".
2. Press the MENU SET button.
3. In the menu that comes up, scroll with the up and down buttons until a menu item named "COL. EFFECT" is highlighted. Now press the right arrow button, and select the desired color effect. (Cool, warm, sepia, B&W).
Apr 07, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic S-VHS-C movie camera
1. Take out the tape - AND TURN THE CAMERA ON.
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS
CREDIT TO LABBER
Feb 16, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
Open Questions:
Panasonic NV-MX500B Mini DV Digital Camcorder Logo
258 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
