Question about KitchenAid Superba KSRG25FK Side by Side Refrigerator
Kitchen Aid #KSCs25INSS01: Outside of Freezer is very hot, jumped down to -15 degrees - will not allow readjustment.
I recently had the same issue of the sides/center becoming hot on my kscs25inss01. The cooling fan would not come on. I kept unplugging and waiting for a while then re-plugging in to get the fan to work for a while (it would run about 12 hours then get hot again, it also takes 7 minutes for fan to come on after plugged in). I also placed a small box fan at the rear vent pulling the air out. I ordered the contoller board and replaced it, now, the fan comes on and it is staying cool.
Replacement:
I removed panel in lower back,
removed inverter box next to compressor,
removed gounding wire on frame,
then removed the controller box - metal box along side of refrigerator
Popped out old board ,
moved the center jumper from old board to new board in same location,
and plugged everything in and sealed it back up in reverse order.
Posted on Apr 08, 2010
  • 28 Answers
The outside of the freezer is very hot because it's try to dissipate the heat load in the freezer. You have have recently put extra load in the freezer or forgot to close the door.
Posted on May 24, 2009
I have a kitchen aid superba and the outside black liners are really hit what does this mean?
Transom between fridge and freezer is usually haeted to stop condensation when you open freezer door.
it shouldnt be that hot that the seal becomes soft and flexable. normally comressor should pass hot gas through condenser first to get rid of majority of heat then to go to the mullon heaters(outer frame). By this time it would be a lot cooler.
If it is too hot to touch the condenser fan is not working to cool the condenser and compressor.
Nov 21, 2012 | Refrigerators
Water, but "no ice" in my Kitchen Aid
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 28, 2011 | KitchenAid KSCS25FKSS Side by Side...
We have question to ask you for Miele Laundry dryer model T4804 C. Our client will install this model in the apartments. They suggest us to connect Dryer vent pipe to the main kitchen exhaust duct of the...
if you use the kitchen exhaust it will ruin the kitchen ducts and forse flow hot air and lint onto the range hood into the kitchen . . stupid advise .. it needs to be ducted directly through the wall to outside using a rain gard the temp can get as high as 47 degrees hot but not too hot it forses air out at a ratio of aprox 15 psi
merry christmas
Dec 22, 2010 | Dryers
I have a Kitchen Aid Md# KBLA20ERSS The
Lack of airflow up to the refrigerator. could be a defrost problem, a fan motor not running, a damper staying closed, a food obstruction, or something else altogether.
May 09, 2010 | KitchenAid (KBLA22ER) Bottom Freezer...
Kitchen Aid ice maker is making a pumping noise. The noise is itermitten. It still makes ice. Freezer is at 5 degree and fridge is at 34 degree. Aquasensor filter is at 44 percent left. Thanks...JA
noise from ice mker can only be the ice maker unit... turn of icemker for a while and see if tn=he noise comes on during that period . if not replace ice mker head . mm
Dec 07, 2009 | Dishwashers
My Kitchen Aid KSCS25INSS will defrost the freezer up to 57 degrees sometimes twice a day. I cannot use the ice maker because I end up with a large block of ice after one or two days.
57 degrees is pretty hot. If it occurs on a regular basis day to day, it sounds like a defrost cycle malfunction.
There is a calrod heater imbedded in the evaporator coil behind the panel in the freezer compartment. It comes on approx. 2 times a day. The compressor is shut off and the calrod (which looks a lot like the bake element in an electric range) is turned on. It gets quite hot, but a thermostat mounted on top of the evaporator coil, shuts the heater down when the coil reaches approx 50 degrees. If this thermostat ( often called a limiter ) fails to open in time, the temperature in the freezer coil box can easily reach 100 degrees or more. If so, this could be your problem. Remove the rear panel in the freezer compartment aand locate this small disc thermostat and replace with new.
Oct 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Fridge KSRF25FRBL00 - Hot Panel between doors
This strip is warmed to prevent condensation forming here during humid weather. Some models use a refrigerant pass of the compressor to warm this strip other use a heater that can be controlled by a 2 position switch in the refrigerator control panel that reads something like "Turn this on if moisture appears on cabinet exterior". If you have no such switch you should be aware that the strip is ALWAYS warm but barely noticeable until you develop a problem in the cooling system.
Check temperatures in the freezer (Zero Degrees approx.) and refrigerator (Approx. 30). If these are normal don't worry about the heat from that strip. If you find a temperature not normal you have the beginning of a cooling problem unrelated to that strip.
Aug 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Kitchen Aid Superbra Freezer Settings model ksrs25qf00
21/2,will give you 0 to 8 degrees,the hiher you set the dial the cooler it gets in the freezer-mike
Oct 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba  KSRG25FK Side by Side Refrigerator Logo
867 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
