Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
HCN4226W 42 in. Rear Projection... Problem: TOO HOT
The set had blown the convergence module, at that time I also figured I would replace the CRT coolant and remove all boards and clean them all up. All work was done and the TV works fine, the only thing is the transistor that runs the flyback and the convergence module runs HOT, I am worried the same break down will occour, is there any info on how to get the set to run cooler so it will last longer, maybe manually adjust the convergence on CRT's  or a larger heat sink. Any tune up help would be great.
  • JAVCO Jan 23, 2008
    The old board had a perfect solution, I used the old heatsink from the convergence module and added it to the new one, it runs much cooler, and less to throw in the garbage. I guess samsung engineered in failure so we can keep buying new stuff. Thats big biz for ya..
    President:
  • 4,402 Answers
These ic do run hot some people have hooked up pc fans to cool them off.
Posted on Jan 22, 2008
  • Cary Farah
    Cary Farah Jan 23, 2008
    please mark the post solution as fixya!
Picture bowed
Recheck ur connections and the covergence board the same make or return and exchange for another convergence board.Sound like u still have convergence problems.
Jun 11, 2010 | Samsung HCN4226W 42" Rear Projection...
I have a samsung rear projection hcn4226w the picture has a couple horizontal distorted spots on it and the box that says what input you are using there are two instead of one
You have a convergence problem. It is much easier to replace the whole module, than just the STK's, no soldering required..It is so easy to do and electronics skill level is not required.One screw and five connections(plug in) is all it takes.The part number you need to order is BP95-00142E convergence amp. I would google search it and find it at the lowest cost
Apr 18, 2009 | Samsung HCN4226W 42" Rear Projection...
Coloring is off and there is a ghosting effect
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
Jan 30, 2009 | Televison & Video
TOSHIBA TV- HCN4226W convergence PROBLEM
I charge 285.00 at my shop ,so if you cannot fix it your self you are looking at repair anywhere from that price or more .You have 2 STK ics these are your convergence Chips .You would need to replace both of them.If you can solder you have it made.
Dec 17, 2008 | Samsung HCN4226W 42" Rear Projection...
Blue ghost
Replace convergence IC'S and check values of convergence circuit resistors.
Aug 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W Rear Projection TV
You can get the convergence board by clicking here.
The service manual you might buy it from the same place.
May 23, 2008 | Samsung HCN4226W 42" Rear Projection...
HCN4226W problem
Voltage regulation problem...accordianman
Feb 15, 2008 | Samsung HCN4226W 42" Rear Projection...
Convergence issues?
most likely the convergence board.
Ordered complete convergence board, ask samsung for part number Convergence AMP PCB $108.44, from www.samsungparts.com
or could send it in to ptscorp.com for repair.
Dec 23, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W Service Menu?? For convergence issue????
The resistors on the new module are not 100% Identical in resistance to the originals on your board, to access the svc menu you will want a service manual and will require some patience. It can be tricky I would personally call a repairman with convergence in mind. Or order a manual and read the conv section several times. http://www.eserviceinfo.com/index.php?what=search2 Is one site, might have to purchase one.
Jul 06, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
