Question about HP PSC 2175 All-In-One InkJet Printer
Scanner failure Scanner failur
  • 79 Answers
You just open start-->settings-->control panel-->scanner and camers
delete old scanner
click add imaging device
you can now reinstall
Posted on May 24, 2009
Whats the meaning of error E0202 canon ir copier
Description
An error occurs during the Scanner Unit (Paper Front) HP detection operation (outward).
E202 -0002 -04 Title Scanner HP error
Remedy 1. Connector disconnection/open circuit of the Scanner HP Sensor (SR2).2. Failure of the Scanner HP Sensor (SR2).3. Failure of the Scanner Motor (M1).4. Failure of the Reader Controller PCB (PCB1).
May 11, 2016 | Canon Office Equipment & Supplies
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Try to copy and get scanner failure motice
scanner failure is a hardawre problem. try to copy again and check if the scanner light is on. once the scanner light is not working then try to return your printer in the store that you have purchased it.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanner Failure
Scanner failure means the scanner is not making enough light to see the home position. It happens when the scanner lamp ages or is covered with dust. Cycle power is just power off and on again, and see if it goes away.
Jul 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
Try to print--scanner failure appears
I think your printer has been, for some time now, trying to tell you something and the scanner failure message
is the last in a series of messages.
First, the copier and the printer and the scanner worked fine, "for years",
Then, the copier stopped accepting scans, while printing from data sent by your computer.
Then, you received a scanner failure message again, and will not accept data from your computer, and
"won't print at all"
Your printer/scanner/copier/fax has needed service for some time after years of continuous service.
Evaluate now, based on its initial cost and the lesser cost of All In Ones whether you have already
obtained sufficient service to amortize the cost over time, and you may conclude that service is eitherr
cost effective or ineffective at this time.
Apr 17, 2009 | HP Office Equipment & Supplies
Scanner failure message
dont worry
just install it in ur pc and just setup all setting to its default
Mar 18, 2009 | HP 610 Color Copier
Scanner Failure
The only thing I can surgest is that you check installed programs I found that the 750 is very fussy about being the only kid on the block. Maybe worth trying a commercial program that says it will remove "junk" from your hard drive
Aug 24, 2008 | HP PSC 750 All-In-One InkJet Printer
Scanner failure
After turning on the printer, I am getting a message stating "scanner failure" turn off printer. Can't do anything else.
Aug 14, 2008 | HP OfficeJet D135 All-In-One InkJet...
K80 "scanner Failure"
same problem here...error message says scanner failure - power off then on, but also doesn't work , ges what , id did buy the same in 2the hand , also same prroblem this is sh...
Jan 11, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Scanner failure
scanner failure, turn unit off and back on, does not help
Oct 01, 2007 | HP OfficeJet d145 InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
396 people viewed this question
Seeker5211
Seeker5211
