Question about NAD C272 Amplifier
Excess clipping on nad 372 amp
I have constant clipping problems with the Nad c372. dvd,classical music,cable movies. Unit in always clipping and shutting down. it is the same if i use soft clipping switch on. Something is wrong- the volume has to be turned almost all the way up to hear sound track. One loud noise an it shuts . I must have a lemon. Ken
  • 28 Answers
Check the input from the pre-amp stage it probably has a high input gain that supposedly in only range of a millivolts 1/100ths of a volt usually 50 to 100mV, i.e. to avoid clipping of sound waves at the power amp. you have to minimize the output voltage coming from the audio/sound devices from its equalizer settings, or maybe either pre-amp stage I.C. has a leaky capacitor, or power amp stage is also defective. hope this help good day ;-)
Posted on May 24, 2009
อิอิ ขอบคุณคับ
My NAD C372 integrated amp was working normally everyday. One day, on pushing in the "Power On" button, it did not light up. No response at all.
It could be anything from a blown fuse from a power surge to a shorted capacitor ijn the power supply. There are fuses in all amplifiers. Locate it and test it with an ohmmeter.
Dec 16, 2013 | NAD C372 Amplifier
How do I connect a cd player to both a tv and an audio amplifier so Ican play either Cd's or DVDs?
Does the TV have a line audio outpot (red and white jack)? If so feed the amplifier input from there.
Dec 23, 2012 | NAD C372 Amplifier
Sound distortion with NAD T 514...
You are probably clipping in that midrange. Since the DVD player is fine and CD player is distorting: they are line level outputs, If you are running those through an equalizer- the equalizer should allow you add in a 10db attenuation.
If you are running them straight to the amp, The CD line level output should be about 1.5 volt peak to peak, it may be the line level input of your amp is only 1 volt and the DVD player simply has that level of output so does not clip..
Simply adding into the cable a 0.1 microfarad polyester capacitor for each channel should be enough attenuation to avoid clipping. The midrange is where you hear the most content in large part because that is the range that the human ear is most sensitive to. Which is why that portion clips. The DVD audio is actually recorded to the same specs as CD audio. You can confirm this by playing your CD disk in your DVD player. .
Sep 25, 2012 | Audio Players & Recorders
How do I connect a Mirage Omni s-10 Sub Woofer and a Parasound Model 2100 Pre Amp to the NAD C372 Amplifier?
You DO realize the preamp is duplicating stuff in the Nad C372, right? This Preamps adds nothing but PHONO connectivity and control. That's why they're called "preamps".
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-C372-Amps-manual/id/8043dj592/t/2/
http://www.retrevo.com/support/Mirage-OMNI-S10-Subwoofers-manual/id/14438ag918/t/2/
Model 2100 Picture and article:
Use the Sub Out pair on the Preamp (joined by an RCA Y-cable) for the Sub Input on the sub (duh):
http://www.hometheaterhifi.com/preamplifiers/362-a-secrets-preamplifier-and-power-amplifier-review.html?showall=1
Run RCA from the Preamp Main Out to the C372 Aux In to hear any sources attached to the preamp.
Or, if you don't NEED the preamp because you don't have a turntable,ditch the preamp and connect the sub using the speaker outputs on the NADS, according to the manual.
Mar 08, 2011 | NAD C372 Amplifier
Nad c372 problem with left speaker output
Hiya, did you try to swop the inputs as well and see if the problem swops. Try that as the input could also be low. If so try change the cable.
If not there try cleaning out the balance pot with switch cleaner (have to open to that and only you are comfortable).
If thats not there then likely an internal problem and will have to send it in.
Best of luck
Jul 14, 2009 | NAD C372 Amplifier
Right loudspeaker problem
Doesnt sound like the selector as it "sometimes" works. Redo the speaker connections on the back of the amp and speakers first. If it persists, swop the speakers and cables, if the problem swops, then it could be inside the speaker or the cable, if still the same then amp has dry joints/loose connections probably
Jun 24, 2009 | NAD C372 Amplifier
Nad c372 prob
The unit is detecting a problem and shutting down in what is usually called "protect" mode. Look for bad connections on the board near the voltage regulators.
Dan
Sep 05, 2008 | NAD C372 Amplifier
NAD amplifier / Plasma/ DVD player
Hi Marie, still need someone to connect it up for you? I could talk you through it.
Apr 23, 2008 | NAD C372 Amplifier
Nad c372 Remote Control
Hello Robert,
If the standby/protection indicator on the amplifier blinks when you specifically press the volume +/- key, it obviously indicates that the unit is receiving the remote's command.
Try the following while pressing the volume key on the remote:
1.- Put your ear as close as possible to the volume control knob and listen for the sound
of a motor spinning, if you hear it, the volume control assembly needs repair. If you
hear no sound, proceed to next step.
2.- Gently rotate the volume control knob on the amplifier unit (it might be stuck and
needs a "little help").
If none of the above applies, the unit needs to be opened and troubleshooted. I've seen many instances where the volume control motor was not properly connected to the board or the assembly was put back incorrectly (specially in units that have been opened to be refurbished). I've heard NAD has a limited warranty for refurbished items. It might be wise for you to check before sending the unit for repair at your expense or trying to tackle the problem yourself. Hope this helps.
cancerags
I
Dec 26, 2007 | NAD C372 Amplifier
No power
Unplug for 20 min. and then plug in to try and see if it will come back on.
Nov 27, 2007 | NAD C372 Amplifier
NAD C272 Amplifier Logo
324 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
