Question about Dyson DC25 Animal Bagless Upright Vacuum
I have the animal dyson and the ball is sticking and getting stuck, making it very hard to push. Help please
The ball is sticking and keeps getting stuck. It just happened the other day while I was in the middle of hoovering. There is still suction etc
  • Dyson Master
  • 1,335 Answers
Make sure the screws holding the two halves of ball together are tight
Posted on Jan 29, 2014
4 Suggested Answers
  • 55 Answers
SOURCE: Dyson Animal hose collapses when using attachment hose
You have a clog in either your hose or your wand. You need to take off the wand and hose and inspect them.
Posted on Dec 02, 2008
SOURCE: no suction on dyson dc24 ball
Well i just fixed my Dyson Ball with the same problem you have. My wife and i found out it was a crumpled receipt in the lower section of the hose at the upright/handheld pivot #3 in diagram and it was catching cat hair and other things. I began by removing the canister and turned on the vacuum to see if the direct access to the fan had suction. Then i moved to #5; i reattached the canister and threw in some cat hair into it from the bottom. i turned on the vaccum to see if it spinned around; it didnt. I then moved to #4, i removed the head and then turned on the vaccum to see if maybe the head had a leak at the top connecter; as i predicted the strength was minimal. I then worked my way to #1 to see if the strength was the same or if there was a difference. no difference for us. Well then it must be #3.. of course the last one i checked. I used a small flashlight and peared in and i didnt see anything... i then used a coathanger very softly as to not puncture the hose. i then noticed some hair being pushed out but the main culprit wasnt showing. my wife gave me needle nose pliers and i pried the hose off of the top connection in #3; so i could get a better look; you may be able to push it off with your hands. and viola! a crumpled reciept for 3 Monster energy drinks.... the same ones....i drink... oops!... hopes this helps. just go through it step by step. youll know its working once stuff begins to spin in the canister. almost regretted throwing that dyson registry junk away.
Posted on Jul 22, 2009
Dysonteam
  • 167 Answers
SOURCE: No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Posted on Apr 22, 2010
When using my dyson ball the ball Is getting stuck.as I move it forward it will go a few inches then stick,if I push hard it will make a click sound &roll again but stiffly. I can't see obvious cause
There are bearings in the ball and on the vacuum that may be clogged with dust or debris. There could be a bad spot on the actual ball itself.
Mar 20, 2016 | Dyson Vacuums
Why does the filter in the ball keep popping out?
Hi Mrs Killick, it's Jack at Dyson.
To resolve this, try removing and replacing the post-filter, as shown in our filter wash video guide below:
When replacing the filter, make sure you push it firmly into place, until you hear a click from the red locking catch.
If you continue to have difficulties after you've given this a try, please contact the Dyson Customer Helpline directly as I'm confident we can help you with this. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 30, 2015 | Dyson DC25 Animal Bagless Upright Vacuum
Why does dyson dc39 ball drag on floor which scratches hardwood and makes it difficult to push on carpet. Just started doing this after four years.
It sounds like the axle connections have gotten dirty or bound with animal hair or other material. Cleaning the axles can resolve this issue. Contact Dyson for assistance here:
http://www.dyson.com/support/repairsandservicinginformation.aspx
Ensure you have the correct model number and purchase date when talking with the representative.
May 17, 2015 | Dyson DC39 Animal Canister Vacuum
Ball won,t rotate keeps getting stuck
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC25. If the ball shell won't rotate, it's likely that the post-filter is out of place. To resolve this the filter should be removed then pressed back down into place firmly - you should hear and feel a click from the red filter catch once the filter is correctly secured:
If you have any further difficulty with the ball or the filter after giving this a try, please get in touch directly as I'm confident we can resolve this for you. You can reach our experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 31, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
Dyson animal ball
You need to call Dyson. We had the same problem with 2 of them! When we installed new carpet, the newer machine was literally impossible to push. Long story short, they advised us to remove all of the gaskets on both heads. Their better now, but I question the quality of a product which has to have parts removed in order to function. Also, I suspect that those gaskets kept dust from being introduced into the interior of my home. I doubt that I'll ever own another when these 2 die. . .
Jul 26, 2017 | Vacuums
Dyson animal ball
Hi Max, I had a similar problem with mine a couple of years ago. I had just cleaned all of my filters on my Dyson, One of them being the one in the ball. Was almost impossible to roll across the floor, I messed with it for a couple of days, no solution. Called Dyson, the technician I talked to thought it might be the entire head causing problems, they sent a new head it was under warranty so no cost to me. Problem still existed. I took the ball apart and looked closely at it and it seems I had screwed it back together wrong after the filter cleaning. Long story short, check to see if the ball is put together correctly. Hope this solves your problem
Mar 25, 2017 | Vacuums
Dyson DC41 animal complete stuck in upright position - how do I get it down. Have been on hold with Dyson for hours.
The wheels are probably jammed and won't recline. Mine was stuck pretty bad, and after a half hour of trying to figure it out I just picked up the vacuum and slammed the wheels pretty hard, and it came loose. No problem since. Pushing on it hard did nothing, and gave me the impression I could break the vacuum, but all it needed was a good jolt.
Aug 03, 2013 | Dyson Bagless Upright Vacuum DC41 Animal
Roller ball stuck
Most common problem is the motor filter inside the ball is not inserted properly, or it has jumped out. Take off the access panel on the ball and make sure it is properly inserted.
Regards
Dyson Independent Expert
May 14, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
Ball filter is popping up, stopping ball rotating and ball area is getting hot
I'm sorry to hear you're having difficulties with your DC25 Animal. If the filter inside the Ball will not stay in place during use, please make sure that when you refit it, it locks into place with an audible 'click'.
I can confirm it's normal for your Dyson to become warm during use, but if you're concerned that it seems excessively hot, I'd encourage you to get in touch with us directly so we can help. You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Mar 16, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
Dyson DC25 Animal Bagless Upright Vacuum Logo
1,401 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
