Question about Nokia 3110 Cellular Phone
SIM Card not recognized.
Water ingress has taken place and I removed the SIM and battery and dried on sunlight.....after that my mobile is recognizing every SIM except the SIM which was earlier in the mobile.
Also the SIM is being recognized in every mobile.
I have done firmware update but no success.
  • sekhar_pd May 24, 2009
    Can I be sure that if I change the SIM with BSNL my mobile will work?
  • sekhar_pd May 26, 2009
    I went to BSNL office to get new SIM but this too doesn't worked....then I went to nokia care and they solved.
    Problem Solver:
  • 7 Answers
The nokia 3110 is not a powerful device it will surely not recognise the sim because it contained the data which might be copied to the phone memory as well as the sim card so during the sim after being wet & dry was certainly not going to be recognized by the cell as its data was corrupted
Posted on May 24, 2009
Device doesn't recognize sim card
this is a problem with IC see the diagram attached. go to the repair shop cell. Merry Christmas.
Dec 20, 2013 | Haier Cell Phones
Tip
How to repair your Mobile when it dropped in water?
<p><span>If you worry as your mobile phone drop in water. It may happened by rain or else. However, there is no need to panic. You can save your mobile by repairing it.</span><br /> <p><span> </span><br /> <p><span>. Quickly open all cover part as possible such as the cover, SIM card, memory card battery, etc</span><br /> <p><span> </span><br /> <p><span>.Take a piece of dry cloth or tissue paper for removing the water. If you sure that dry it completely, or some inside part out of your reach.</span><br /> <p><span> </span><br /> <p><span>. You can use a hairdryer and begin to drying the mobile by put it in the place where battery is located, and keep it too close to the mobile it may harm the electrical mechanism of the mobile phone. </span><br /> <p><span> </span><br /> <p><span>. Keep the mobile phone in sun light or in warm place for twenty to thirty minutes.</span><br /> <p><span> </span><br /> <p><span>. You may take off the covers and battery from the mobile phone. Keep the mobile in a dry or warm place to remove the water from the mobile phone. </span><br /> <p><span> </span><br />
on Dec 24, 2010 | Cell Phones
Tip
NOKIA PHONE-LOCK RESET Q. What is a Phone Lock? Answer: From Nokia's...
Answer: From Nokia's webpage:
"The Phone Lock prevents your phone data from being accessed if
Your phone is stolen.
"The lock code is a number that prevents unauthorized persons from
Using your phone. These control codes are for your protection."
What is THE-NOKIA-UNLOCK:
The program exploits a design flaw in the nokia mobile phones to remove
The Phone Lock protection.
The program was tested on Nokia 6630 and Nokia 6680. The program
Should work on any other Symbian based mobile phones (including Sony
Ericson and all modern nokia phones and many others).
This tool does not remove the sim-lock.
How to use:
You need two mobile phones.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card (MMC) from the locked phone and put it into a
second mobile. Install FExplorer on the second mobile phone. Create
the directory E:SystemRecogs and copy the-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THE-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to "12345".
Why does this work?
The Phone Lock disables the key pad, Bluetooth and the USB port. This
makes it impossible to access the data stored on the device without
knowing the correct code.
Nevertheless the MMC is not disabled. Nokia's OS has a lot of undocumented
features. One of them are 'recognizer' that can be used to execute a
program when the phone boots.
A recognizer is loaded and executed when a drive is mounted. The MMC
is mounted when it is placed into the mobile phone _even_ when the phone
is locked.
THE-NOKIA-UNLOCK is a recognizer that implementes yet another undocumented
feature to perform a hard reset (by software) on the phone.
Note: The same recognizer-autostart method can be used to quickly install
a backdoor on a locked mobile phone or to propagate a virus: Get in, Get
Out, Get Away.
on Jun 04, 2010 | Cell Phones
I have dropped my E5 into the bath
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days or in front of a warm fan heater for several hours then reassemblethe phone. Hopefully it will work properly but if does not work then it isfaulty and you need a new cell phone.
Jun 27, 2011 | Nokia E5 Cell Phone
I dropped my phone in some coffee. I am leaving it to dry now, and have taken the battery out to dry. I have found another phone, put the Sim Card in, and it has all my contacts, but it wont send texts? It...
As you said me usually sim card will not get damaged by water.Just need to check up remove you are sim from you are mobile and check with other mobile there also if you find the same problem means you need to contact you are customer care change you sim to new sim do not worry you will get that number only.Thanks for you are question.
Jun 17, 2011 | Cell Phones
Tip
Dropped the cell phone or mobile in water
Dropped the cell phone in water
If you would have accidently dropped your cell phone in water or it fell in water you can try fixing it be these below tips
1. Remove the battery of the mobile and try drying it with a hair dryer
2. Put the cell phone in a raw rice container for a day, the rice will soak the moisture and the mobile will become dry from inside
3. After that put the battery back on and try switching, there are more chances now that it will work
4. Never try to instantly switch on the cell phone after taking it out from water you should follow the above steps, switching it on instantly can lead to short circuit in mobile and the cell software can get damaged
5. You can also put the phone in light sunlight (not in very hot direct sunlight) after removing the battery do not put the battery in sunlight though
6. Also make sure you keep the SIM card out of the mobile
By taking these steps you can make a fair attempt to save your mobile from dying.
Regards
Vikram
on Dec 02, 2009 | Cell Phones
Cell phone got wet. It doesn't work anymore. How can I retrieve phone numbers, etc?
hello,
u hav to put ur battery out and open ur mobile fone after it put ur mobile fone board in sunlight for 2 or 3 hours then close ur set and put ur battery into it and turn it on..
Jan 06, 2010 | Verizon Communications LG enV Cell Phone -...
E71 memory card unreadable
please check it with another battery
May 03, 2009 | Nokia E71 Smartphone
Sony ericsson s500I
There is a good chance that your sim card is too old a version to be read by newer phones. Although the shape is the same, the format just isn't recognized. Time to upgrade your simcard is all.
Dec 22, 2007 | Sony Ericsson Mobile Bluetooth Car Kit...
Phone doesn't recognize the SIM card
The sim card holder has a tiny slide mechanism. After inserting the sim card and pressing it against the body of the phone, place your finger over the card and slide it gently forward. The tiny plastic part that holds the card will snap it into place. Hard to explain, but it will work.
Dec 17, 2007 | Motorola Mobility V66 Cellular Phone
Nokia 3110 Cellular Phone Logo
358 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
