Question about Toshiba Satellite M55-S135 Notebook
Toshiba satellite M55 not turning on
Was working fine yesterday on battery. allowed to run until got low battery and hibernation warning and hibernation shut down. usually when this happens I just plug in adaptor and powers back up right away. now after start key is pushed I get maybe 3-5 seconds of green power light, screen stays balck then all power goes away. tried plugging in to recharge with both adptors and no response (power light in left front does not register).
  • 909 Answers
Either the battery is faulty, or the charger is faulty.
Check the fuse in the mains plug, or even the power point you are using could have a bad connection.
Test using a lamp that you know works or a radio or something and try the charger in another outlet to find the fault.
Posted on May 24, 2009
How to calibrate battery laptop toshiba satellite m45-s359
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Dec 13, 2010 | Toshiba Satellite M45-S359 Notebook
Toshiba satellite A100 screen goes black (like hibernation mode) when I plug in my new iTouch 4th generation. No keys work and nothing fixes it until I turn off the computer. It is fine when the iTouch is...
Word. Only two things I can think of to solve this problem one is to make your pc into a linux/windows dual boot. just plug in your iTouch when you are running linux. There should be no problem at all and no loss of files. two is to do a full system recovery, which means you lose all your files and programs. reply if you need help with doing either one or just google it.
Nov 30, 2010 | Toshiba Satellite A100-S8111TD Notebook
MY toshiba satellite laptop bleeps all the time. it is a soft bleep about it bleeps about every 15 seconds laptop is running well. can any body help with this
This may be a problem with your low battery warning.
Go into control panel / power options / and turn off low battery warning.
Hope this is what it is.
If not write back and we can try something else
Sep 08, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite M55-S325 PC Notebook outsde case
You definitely need to bring your laptop to the Toshiba shop near you. There they can facilitate the replacement of your laptop's body (casing). It is a critical task to do and I think a Toshiba authorized shop can help you with this. Thanks.
Feb 03, 2010 | Toshiba Satellite M55-S325 Notebook
Toshiba satellite m55-s3314 turns off as soon as it is turned on
Remove battery, press and hold power button for 5 seconds, reinsert battery and make sure it is securely in place
Jan 10, 2010 | Joy Satellite M55 S3314 Laptop PC
Satellite (A75S206) runs well from outlet but never from battery. Was told that mobo can't accept dc. Need new mobo. True?
hello loyd516,
Have you tried a new battery? They are much much cheaper, and a whole lot easier to replace than a motherboard.
Here are replacement batteries that I found searching with Google.
http://www.google.com/products?q=Satellite+A75-S206+battery&hl=en
According to Toshiba, there has been a battery recall for your specific model.
If that is the case I would definitely contact Toshiba support about it. Maybe you will get a free battery out of the deal. Who knows.
Here is the link and the list(your model is highlighted)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=1501060
Sony Battery Pack Recall Programs Document ID: 98082080 Posted Date: 10/10/06 Last Updated: 10/30/08 Operating System: N/A Category: Battery Distribution: Public
Applicable Models:
Satellite A70-S256, A70-S2561, A70-S2362, A70-S2491, A70-S2591, A70-S2482TD, A70-S2492ST, A70-S259, A70-S249, A75-S206, A75-S2091, A75-S2292, A75-S2291, A75-S229, A75-S209, A75-S2061, A75-S226, A75-S2261, A75-S276, A75-S1255, A75-S1254, A75-S1252, A75-S1253, A75-S1251, A75-S125, A75-S2131, A75-S213, A75-S2112, A75-S2293, A75-S2311, A75-S231, A75-S2111, A75-S211, A75-S2761, A75-S2762, M30X-S1592ST, M30X-S1593ST, M30X-S191TD, M30X-S181ST, M30X-S171ST, M30X-S221ST, M30X-S221TD, M35X-S149, M35X-S1491, M35X-S109, M35X-S309, M35X-S3091, M35X-S329, M35X-S1631, M35X-S163, M35X-S1143, M35X-S1142, M35X-S114, M35X-S3111, M35X-S311, M35X-S1611, M35X-S161, M35X-S111, M35X-S1492, M35X-S3291, M35X-S349, M35X-S3491, M35X-S3112, M35X-S1141, M50-S418TD, M50-S4182TD, M50-S5182TD, M50-S5181TD, M55-S135, M55-S325, M55-S3262, M55-S2253, M55-S3251, M55-S1351, M55-S1352, M55-S3511, M55-S351, M55-S3294, M55-S3293, M55-S3292, M55-S3291, M55-S329, M55 Series, M55-S2252, M55-S3512, M55-S3315, M55-S3314, M55-S321, M55-S3313, M55-S3312, M55-S3311, M55-S331, P30-S6362ST, P30-S6363ST, P35-S609, P35-S6091, P35-S6111, P35-S6311, P35-S631, P35-S6112, P35-S6053, P35-S6052, P35-S6051, P35-S605, P35-S611, P35-S6292, P35-S629, P35-S6291
Tecra A3, A3-S731, A3-S611, A3-S711, A5-S416, A5-S237, A5-S516, A5-S136, A5-S3291, A5-S3293, A5-S3292, A5-S329, A5-S118, A5, A5-S6215TD, A5-S116, S2, S2-S511TD
Jul 11, 2009 | Toshiba Computers & Internet
Toshiba M55-S135
check your battery on some other's laptop, i think the battery life is over, you have to replace the battery
Oct 29, 2008 | Toshiba Satellite M55-S135 Notebook
Doesn't start up
remove the primary battery and plug the computer into an AC outlet using the AC adapter. If the computer starts up, one of the batteries need to be replaced. If the battery light on the of the comoputer is blinking, the battery has reached a low batery level, which may not allow the computer to start up. Plug the computer into an AC outlet using the AC adapter to start the computer and allow the battery to charge.
Dec 30, 2007 | Toshiba Satellite M55-S3512 Notebook
My laptop wont hibernate!
Typically this indicates a problem with a particular piece of hardware or its driver that is not cooperating when windows tries to hibernate. Do you have anything new attached to the system? If so, try unplugging it, rebooting, and see if it cooperates then. Also, have you checked the windows event log to see if windows reports any particular errors when trying to hibernate?
Sep 02, 2007 | Toshiba Satellite M55-S135 Notebook
Toshiba Satellite M55-S135 Notebook Logo
231 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
