Question about Black & Decker Garden
Hi i can't extend the plastic strimming cord on my bacl and decker. any ideas how to do this? I have tried everything other than taking it to bits! thanks ian
    Scholar:
  • 72 Answers
If the trimmer works like most trimmers it has a "tap and go" system. This means you just tap the bottom of the trimmer to the grass surface while it is spinning. Then there is a knife that cuts the line to the proper length.
Sometimes this system needs servicing to work as it should i.e you have to take it apart, usually not very complicated.
Posted on May 24, 2009
Corded elec mower wont start. Extension cord is new
Is there power going to the extension cord? If so, is the power reaching the electric motor? If not check the on/off switch and connections.
Jun 28, 2015 | Black & Decker Black Decker 18" Lawnhog...
My strimmer releases nylon cord involuntarily. This is without tapping it on the ground.
Hi Peter:
Check to see if the spring under the "bump" mechanism is missing, or not extending adequately. You could try stretching the spring a bit to see if that would help.
May 13, 2015 | Office Equipment & Supplies
How do I replace cutting head in a Flymo contour 500 strimmer?
Stan try winding the cord in the opposite direction. It may just be wrongly wound.Also make sure it's the right diameter.
Jun 27, 2014 | Garden
How to change the spool in the black and decker grasshog
Is this the cordless Grass Hog? Turn the trimmer upside down so you're looking at the bottom. There are two orange tabs on either side of the spool -- push these in and the head should pop up so you can pull it out.
On the new spool, feed the cord out several inches and stick it through the hole in the trimmer where the old cord stuck out. Then pop the spool into the cavity so that the orange cover faces out (toward you). Pull the cord taut and make sure it is not long enough to hit the plastic guard. If it is too long and it touches the guard, pull the spool off and wind the cord in a little bit. If the cord is too short, pull the spool off and thread out a little bit more length and try again.
Turn the trimmer right side up and turn it on to make sure it works. If you hear a loud rapid thumping sound that sounds sort of like a machine gun, the cord is too long and is hitting the plastic guard.
Jul 04, 2010 | Black & Decker 14" Grass Hog Xp...
Need to replace strimming line
you may simply put cable on the wrong way round
Jun 23, 2010 | Black & Decker String Trimmer Cordless 12"...
Black and Decker corded drill won't tighten around a bit.
the chuck sounds like it is bad or maybe stuck from rust, what you can try and do is spray some WD-40 on the jaws and then try and holding the collar with a glove and run the drill SLOWLY in forward/reverse and see if it loosens up if not you will need a new one.
Jan 14, 2010 | Black & Decker Drills
Have a black and decker 19in electric mower. was
The "wedge" of the plastic lever wears, so you need to replace the lever or build up that section of the lever. Some cyanoacrylate (Super Glue / Krazy Glue) and a piece of a zip tie will work.
Sep 23, 2009 | Black & Decker 19" Electric Lawnhog...
Retractable Iron Cord Stuck
under the knob to press to retract the cord there is a screw,
slacken it ad try to adjust it again.
Jul 26, 2009 | Black & Decker Irons
Garden Logo
61 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
