Question about HP DeskJet 3940 InkJet Photo Printer
Printer cartridge container doesn't stop in the middle
My printer is hp deskjet 3940.
When the ink that came with the printer ran out, I injected a generic into the cartridge. It printed well on its early printing but later the quality of print deteriorated until such time that it stopped printing. The printer's power indicator just kept on blinking.
I tried to clean it by wiping the cartridge's printing head and the roller.
After that the cartridge carrier never stop in the  middle when the  printer cover is lifted when it is supposed to stop.
The power indicator just kept on flashing.
  • HP Master
  • 1,113 Answers
It appears that the injection may have been lethal, it was still using the ink that it carries in its tubes then it mixed with the injection and is now blocked \ faulty. To repair it you could try getting a new set of HP inks.
Posted on Oct 20, 2007
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
When it chooses to "print", page(s) is/are blank HP deskjet 3940
1. Check that your ink-cartridge is not empty.
2. Run the HP Support software (supplied/installed with the printer) to run a "print-head-cleaning-cycle".
3. Replace the printer.
Jul 22, 2010 | HP DeskJet 3940 InkJet Photo Printer
After my printer hp desktop 3940 prints it changes the status from ready to no toner and will not print again
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 03, 2009 | HP DeskJet 3940 InkJet Photo Printer
Can you use HP 3940 printer with only the black ink cartridge in the printer
I think you guy want to experiment on this printer or want to save money of color ink cartridge
for this you can unplug color cartridge and use printer if your query remains then use a empty color ink cartridge.
thanks
ttyagi
Jul 18, 2009 | HP DeskJet 3940 InkJet Photo Printer
Hp deskjet 3940 printer light just blinks.It will not do anything else.
in this printer only one LED present that blinks and two kinds of blinking one slow and other fast blinking
So if slow blinking inyour printer then this may be cartridge error, if you are are using refilled ink cartridge so please change change that one.
and if fast blinking in your printer then you cannot do anything.
in last go to AN Authorised service centre(to know the address of AN Authorised service centre in your city please visit at http://www.hp.com ).
thanks
ttyagi
Jan 09, 2009 | HP DeskJet 3940 InkJet Photo Printer
My HP printer's light blinks, but it doesn't print.
two things to consider.
1. If the blinking is fast (like more than two blinks per second) then the printer is damaged. Either the main controller board is fried or the carriage/ink controller is damaged.
2. if the blinking is slow ( 1 blink per second) this means that either of your cartridges is busted. remove the black cartridge then close the top cover. If the blinking stops, then the black ink is the culprit. If not, replace the black then remove the other cartridge. THis means that one of your cartridge needs to be replaced.
Sep 27, 2008 | HP DeskJet 3940 InkJet Photo Printer
Software download
i have HP Deskjet 3940 printer,i do not have CD TO INSTALL SOFTWARE.PL; DO THE NEEDFUL
Apr 24, 2008 | HP DeskJet 3940 InkJet Photo Printer
HP 3940 Printer not connected
The "remanufactured" cartridges can cause the printer to stop working by making a electric failure in the printer circuits. Those cartridges should be avoided now that HP makes extremely cheap and fragile circuits, not like the cartridge burner's HP's 600, 700, 800.
Jan 17, 2008 | HP DeskJet 3940 InkJet Photo Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
HP DeskJet 3940 InkJet Photo Printer Logo
96 people viewed this question
Clive
Clive
