Question about Radio Shack Pro-96 Scanner
Hand held scanner pro-25 wont turn on
It was working great now it just wont turn back on I try new batteries new power cord nothing.
Is it some some I can fix like replace a fuse or any advice?
Thank you
Sergio
  • ssimental May 24, 2009
    Yes batteries in the right way !
    It wont turn on at all { power or batteries}
    Thank you
    New Friend:
  • 160 Answers
Are the batteries in the right way
Posted on May 24, 2009
My scanner wont come on I turn the switch on and nothing lights up I was wondering if it's dead.
Without model and make it's hard to say. First check the power and or batteries if it's a hand held model. I run into this issue with my Whistler scanner from time to time...I just remove the batteries and put them back in and it comes back.
Apr 23, 2015 | Radio Communications
How do i get it 2 work n turn on again??
Is the battery charged?
Maybe the battery is dead from the power cord having a short in it.
Will it turn on when the power cord is connected with the battery in it?
Feb 10, 2014 | HP Dandelion Breeze Laptop
My pro96 hand held police scanner cuts out or breaks up when police are talking in differant locations of the city, at my house and surronding area it breaks up, at work 4 miles away it is great, i can...
Hi Bill, my name is John. Try checking your antenna for bad connections, also turn your SQUELCH to where you just barely here static, then slowly rotate it until it is clear. ...hope this was helpful
Sep 01, 2010 | Radio Shack Pro-96 Scanner
HP dv7 simply stopped turning on. worked great
What you would want to try is to remove the battery and see if pluging in the power cord will power the laptop alone. All laptops have this capability and this shouldnt be an issue.
But by testing this and seeing if it DOESN'T work then that means there could be one of two things. Your AC power adapter is defective and should be replaced with one that is compatible with your system or that your connection jack is either loose on the inside or broken completely.
However I would stick with trying the cord first before trying to resoder the joint inside the system. I'd leave that to a pro, going back to the battery if you leave it out for a day that should give it plenty of time to discharge any energy it may have in it and you can plug it back into the laptop to try and charge it again either with the same AC power adapter or a new one. If the battery wont hold a charge and you know it isn't because the jack is loose or the AC power adapter isnt defective then you now know you need to replace the battery. You can google compatible batteries and power adapters online or search specific places like Newegg.com or Amazon.
Hope this gives you a better understanding of what may need to be done to fix this!!
check me out at http://ctrlr4repair.webs.com
May 06, 2010 | HP Pavilion dv7-1020us Notebook
Bought new cords for scanners and when plugged in the light comes on but will not read anything
have you tried using another code, sometimes new cord can still be faulty. if you try another cord the same problem comes up then the scanner port might have develop fault
Mar 03, 2010 | HHP Hand Held Products IT3800LR-12 Barcode...
New shell for the Pro-96 Hand Held
http://support.radioshack.com/support_electronics/doc71/71296.htm
12410791 CASE ASSY FRONT Z94228
12410809 CASE ASSY REAR Z94229
Sep 26, 2009 | Radio Shack Pro-96 Scanner
Need to reprogram hand held pro 96
Radio Shack can "CLone" your scanner with one in the store - try that first to see if it will work and let me know.
Aug 19, 2009 | Radio Shack Pro-96 Scanner
Want to scan cell band?
This non-trunking scanner made by Uniden can store 200 channels, and has a frequency range of 25-512mhz with some gaps in the broadcast bands. so cell phone is not possable
May 01, 2009 | Radio Communications
My N70 Won't Turn On At All
petrosp your n70 needs to be flashed with new firmware. In the worst case some hardware got damaged
Aug 11, 2008 | Nokia N70 Cellular Phone
Radio shack pro97
I have the same issue, was working fine, then the scan works but never stops on any freq. nor does the squelch make any sounds. The only sound is the key tones, I have reset the unit and tried new batteries and a different antena. still nothing? any ideas?
Feb 24, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-96 Scanner Logo
287 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
