Question about Canon Digital Rebel XTi 10.1MP Digital SLR Camera Digital Camera with EF-S 18-55mm f/3.5-5.6 Lens + B
Canon rebel xti digital camera mem. card will not lock into place
The memory card for mu canon rebel xti digital camera will not lock down into place. it just bounces back up...any help...thanks in advance..
    Novelist:
  • 164 Answers
It seems that the CF reader mechanical assembly part has loose or out of place an internal part.
It may be caused by excessive force in pushing/pulling a CF memory card, or due to a manufacturing issueof the camera.
The solution is to open the camera, and check what is causing the problem and fix it.
If it's under warranty, I do recommend you to return it. If not, then you will need to pay for its repair, or do it yourself if you have experience, skills and patience in fixing electronic devices.
Such repair will require some philips screwdrivers, a soldering iron, soldering wire, and a st of tweezers.
There are in internet some guides to open and disassembly Canon XT 350D or Rebel 300d cameras. The disassembly process with the XTi 400D is very similar. You can Google fr such guidelines.
Best regards,
Posted on Jul 23, 2009
Canon Digital Rebel XTi camera - sometimes USB wire doesn't register when it's plugged into camera and computer at the same time
Probably a bit of wear & tear on the mini usb socket in the camera.. Put the card in a card reader on the computer just to check it's not the computer
Sep 02, 2015 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebel xti
Tr5y a factory reset on the camera. And try another Memory card.
Aug 19, 2014 | Canon EOS 400D / Rebel XTi Digital Camera
My canon rebel xti will not power up with a cf memory card in place. I tried two different cards. With no card in place it works fine.
check for bent CF pins. Also remove the back cover and make sure the bottom right rear circuit has not come loose and is not shorting out the board
Oct 13, 2013 | Canon Digital Rebel / EOS-300D Digital...
Card reader pins came out
Basically no. You need the pins to connect to the memory card to transfer and store photos from the camera to the card. There is no simple way to bypass it unless the camera can also use another type of memory card, in which case you use that second slot.
Apr 02, 2010 | Canon Digital Rebel XTi Digital Camera
Memory card will not lock into down position. will just bounce back up
It seems that the CF reader mechanical assembly part is loose or it has out of place an internal part.
Best regards,
May 24, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Why does the word, ''busy'' pop up on the canon rebel xti?
This is the camera writing to the CF memory card. Perhaps your card is a lttle slow, so you will see the message. I use the Sandisk Ultra II CF, labelled as 15Mb/sec and it is very very fast indeed - I don't have any lag with my XTi. Try a different CF, if it is fast enough, the message will go away. Ensure you format the card on the camera too.
Apr 13, 2009 | Canon EOS Digital Rebel XTI Digital Camera
Photos are locked
I'm guessing you have an SD card. On the side opposite the "cut-off corner" there is a little switch. Down is locked - up is unlocked.
That should be it.
Apr 08, 2009 | Canon EOS Digital Rebel XTI Digital Camera
New canon eos digital rebel xti
There have been several reports of CF cards that work with all cameras, except the Rebel XTi. It depends on the actual manufacturer of the card. Canon made a change mid-production that affected the data saving. Try another brand of card & you should not have that problem any more.
Jun 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Digital Rebel XTi 10.1MP Digital SLR Camera Digital Camera with EF-S 18-55mm f/3.5-5.6 Lens + B Logo
134 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
