Question about Altec Lansing VS2221 Computer Speakers
Subwoofer makes a sound at computer startup
When i turn on my pc, there is a crackly sound from the subfoofer - even though i haven't even turned on the speakers yet. How is this possible and will this (electric shock?) damage the subwoofer?
  • repo_sanna May 24, 2009
    Thanks for your quick reply! But, this means that i always have to switch on the speakers, even if i wouldn't need them. Seems strange...
    Novelist:
  • 99 Answers
1.yes the electric shock can damage the subwoofer  2.some times a sudden switch off or power cut can result in for such issue . 3.for this issue just make sure that you switch on the speaker 1st before starting the PC, then switch on the PC, & while closing time also make sure you 1st switch off or shut down the PC 1st & then the speaker in last   & more ???...! do keep on writing untill then have happy computing sir...till then See you soon...!
Posted on May 24, 2009
How do I turn off the subwoofer?
it all depends on what do you wanna turn it off.
if its car jst go to audio settings till u find the bass or sub setting
Apr 18, 2017 | Car Audio & Video
Why won't my COMPAQ PRESARIO SR2032X desk top
Please turn off the computer, start hitting F8 at the start-up and then choose last known good configuration. If this does not work, choose Safe mode options.
If still does not work, please try to restore the computer to factory settings. You can try to hit F11 or F10 at the startup to initiate recovery.
If not working, please tell me what error message you get on the screen.
Jun 01, 2013 | Computers & Internet
I plugged in my Altec AP3 Speakers to my computer running windows 7. It does not play. i get sound directly from my PC (it had sound prior to plugging in speakers) however the Altec speakers have no sound
Hello
You haven't specified from which computer source you connects this device with. If it is from the audio out socket of the PC, your PC's audio card [or onboard audio] dirive hasn't been installed yet. Unlike WinXP, Win-7 haven't all driver software in its driver cab when it is installed. If onboard sound should energize, the mother board CD should be loaded. There is audio and video drive [normally NVIDIA] drive should be installed. Anyway, you have to install the dirve. Now it disabled. Go to the hardware confujuration of your system, and look whether onboard audio is disabled. If it is disabled, inable it. If there is no driver installed to it, the system will ask CD. Then insert the CD into the CD tray, and follow the instructions. If your Win-7 is registered, you can get diretly into Microsoft site, and can download the driver needed. OK.
Jun 03, 2011 | Altec Lansing ATP 3W Computer Speakers
How to connect the gemini to the computer
Easy.
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The Gemini's Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select Line In.
http://i.ehow.co.uk/images/a04/fa/r2/subwoofers-as-home-entertainment-set-1.1-800X800.jpg
The Gemini's Output (Record Master) would perform similarly if adapted to your PC's audio input, whatever that may turn out to be (usually Mic, maybe Line In).
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 12, 2011 | Philips Gemini CDM-500
My subwoofer is making a humming noise even though the satellite control is turned off. If I turn it on it makes a terrible noise. My computer icon says speakers are 34%. I just got this system yesterday...
Be sure that your plugs are in the correct port and fully seated. Try readjusting the system volume and adjustment on the speakers, if either is at extreme, overamplification happens....
Feb 17, 2011 | Logitech OEM S220 2.1 Speaker Black...
My toshiba satellite A355D touch pad is not working. my husband told me that probably my kid turned it off. if that is the case... how can i turn it on?
Sounds like your touch pad may need to be replaced.You can't really turn off the touch pad.Even if your child managed to uninstall the touch pad it would load back the drivers at next startup.Chances are the touch pad will have to be replaced.Its possible the touch pad may be disconnected from the motherboard but not very likely though.
Aug 24, 2010 | Computers & Internet
The computer can't hibernate when conected with
1st, I would turn off the screen saver and make sure it's not interfering.
2nd, would see if there where any updates on your manufacturers site for any hardware in your computer.
3rd, I would go into msconfig and disable all startup items, restart computer and see if that helps and maybe something running in the background is interfering
Please let me know if any of that makes a difference.
Mar 03, 2010 | ASUS G1 Notebook
I have a JBL PB12 sub, no power - prev wrenching sound on startup
these a internal power control board defective, send to repair
Jan 17, 2010 | JBL PB12 Subwoofer
Compaq presario
It sounds like you are having startup issues even though you hear it coming on. Sometimes when u have viruses and such you see major hardware inconsistence. My advice download this Free home edition anti-virus AVAST, once you install it will automatically prompt you to do a Boot time scan, which will scan your entire computer for infections at the start-up. That should most likely fix your problem.
make sure to let me know
Feb 11, 2008 | Compaq Presario 5000 PC Desktop
Loud steady sound when turned on
If it's a humming noise you are describing, then it may be that one of the power supply filter capacitors has failed. Of course it could be some other sort of power supply problem as well.
Dec 14, 2007 | Wharfedale PowerCube PC-12 Subwoofer
Altec Lansing VS2221 Computer Speakers Logo
196 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
