Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water dispenser not working on my Whirlpool side by side
My water dispenser quit working, the water pressure is also low, and my icecubes are hollow
    Problem Solver:
  • 6 Answers
Cheek out the soloniod valve at the rear side of the refrigerator.and then cheek the pipe it should be stright.
Posted on May 24, 2009
Low water pressure in ice maker and water dispenser I changed the filter but water just dribbles out of water dispenser and ice maker makes hollow cubes
Make sure the water line to the back of the fridgeis not kinked.Ifit is replace it. Hope this helps,If so give us a 4 thumbs up. THANKS
Mar 02, 2011 | Maytag MSD2758G Side by Side Refrigerator
Water comes out of water dispenser in my whirlpool side by side
If the water is dripping out when your not activating the dispenser in between uses then you need to replace your inlet valve. This will correct your problem. If your water pressure is low then you could replace your saddle tapping valve that actually taps into your water pipe to feed the water line to the refrigerator. This will increase your water pressure.
Hope this helps _MJ_
Feb 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water is coming from the water dispenser and ice cube are hollow water is coming out the bottom of frig on the floor could it just be a stopped up filter?
You definitely have a water flow problem. Plugged filter, broken line, low water pressure will all create these symptoms.
Eric
Feb 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Some of my ice cubes are hollow from my ice maker.
Sounds like not enough water is being sent to the icemaker from the water valve. Could be a defective valve or a water pressure problem.
If you have a water dispenser, does it seem to have good water flow?
Oct 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool side by side refrigerator is not making enough ice. The water dispenser is working fine .what can i do?
Check the water flow valve. I've changed mine three time already and it fixed the problem each time. If the cubes are hollow it is another sign of water flow valve.
Aug 30, 2009 | Whirlpool GC5SHEXNS Side by Side...
I have hollow icecubes too, and water from the un frozen icecubes spills in bin and all the other cubes stick together. IS There Not a way to adjust the timer on the icemake to turn slower so they will...
your hollow cubes tells me your ice-mkr is not receiving enough water. first check water supply. does your refrig. have a water filter? also you could have a bad/restricted water valve.
Jul 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool water dispenser and ice maker quits
change your water filter its probably full of dirt and plugged
Jun 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water and icecube dispenser constantly leaks water on floor
Needs new solinoid valve. Usually located on the back bottom of refrigerator
Jan 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water in ice cubes
Hollow ice is usually caused by low water pressure. There is a mesh strainer in the water inlet valve where the water supply is connected. Make sure it's clean and that you have enough pressure. The pressure at the water dispenser may give you an indication of the pressure.
Sep 13, 2008 | Roper RS25AEXLQ Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
199 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
