Question about Canon PIXMA MP150 All-In-One InkJet Printer
ERROR CODE E-4 0. No activity on turning ON the printer
Scaner and printer dosn't work , when it is turned ON there is no activity screen shows E 4 0
  • Canon Master
  • 4,338 Answers
MP150/160 resetting errors: do a EEPROM reset
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 24, 2009
Hp leserjet pro 400 mfp scaner error 52
The scanner initialization did not pass it seems. Try cleaning the glass and white background.
If that doesn't work, the scanner bulb may be faulty - try replacing it.
Sep 09, 2014 | HP Laserjet Pro 400 Mfp M425dn...
Hp laserjet 1132 mfp e8 error code, how do i solve this
Hi Abu Bakarr.
The e8 error is refering to problems with the CIS Scanner. I have attached a link to the product service manual. Read page 122 about the e8 error and perform the 4 steps in the manual to fix the problem. If no luck, the CIS Scanner needs to be replaced. Good luck. http://www.feedroller.com/store/Service%20Manual/HP_LJ_M1130_M1210_Manual.pdf
Jan 10, 2014 | Canon PIXMA MP150 All-In-One InkJet...
I cant make or recieve calls on my nokia c5 03.
Hello:
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 28, 2012 | Nokia C503 Cell Phone
How can i solve this E244 error code
A E244 error code deals with the scaner. When you turn the copier ON will the scanning lamp turn ON? If it dose and you make a copy and thhe scaner moves & start to make a copy and then codes out. The problem is the BLACK scaner power cable has a crack in the coatting and is arching out to the frame o the copier..... It is not a easy fix.... If the scaner lamp is not turning ON???? You may have a blown Lamp or thermal fuse.... You can still find these parts..... The code will not go away till the problem is fixed.. Good Luck
Oct 21, 2011 | Canon NP 6035 Copier
Canon Np 6221 given error E0200
Hi, the error code E200 is related to scaner section.
Try remove copy glass, and manually pull right and back in home left position the scaner assy.
Before doing that, disconect the copier from power network, because the lamp of copier is always under current.
Then turn on the copier
Jul 09, 2010 | Canon Office Equipment & Supplies
After I turn it on it shows an error messaje
there are problem in scanner assembly. please clean care fully and properly of your scaner unit.,than its ok.,
May 10, 2010 | HP Laserjet M2727nf Multifunction Printer
Screen shows error code 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Thanks
Sep 09, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Problem after replacing both ink cartridges on MP160
i want to use just scaner from my cannon pixma MP160, but i don't have catridge or the catridge was broken. can every one resolve may problem?
Jul 27, 2008 | Canon PIXMA MP160 All-In-One Printer
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
380 people viewed this question
old marine
old marine
