Question about Transcend (589307) Media
Write protected message
I can not write on the flash(only read) and when I format the flash memory a message appears: disk is write protected
  • 58 Answers
This problem is due to a virus infected pen drive. Run an antivirus and then try writing on it.
Posted on May 24, 2009
I HAVE A FLASH Transcend (Jet Flash V15) 4GB I CAN NOT USE IT WHEN TRY TO COPY A FILE TO IT A MESSAGE APPEAR THAT THE DESK WRITE PROTECTED AND TRY TO REMOVE THE WRITE PROTECTION I TRY FORMAT BUT NOT WORK...
1.Close all files
2.Select Transcend Pen drive-Right Click-Format-ok.
3.After formatting you can copy all files upto 4GB.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
May 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Cannot format flash drive.... receive message `disk is write protected`
Usually there is a small switch or colored slide which flips between write protected and writable. If there is no switch it may be the software that is on the drive is preventing the format, if this is the case you may need to use a boot disk like Hiren's boot Cd to format it while not booted into Windows.
Mar 15, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
The disk driver is not formated do you want
Flash drives are composed of a memory chip/ storage and USB interface. The above message appears only when the USB interface is working but memory area is faulty. Unfortunately, the chip replacement is not possible.
To confirm that the problem is with the memory area, right click on my computer - goto manage, then disk management and look for flash drive. The flash will appear but no memory would appear.
Flash drives are mostly under warranty for atleast one year. Claim warranty, if possible.
Hope this helps!
CreativeTECH
Nov 10, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Cannot delete in transcend micro sd 2gb memory card.
hi if you look on one side of the disk you will see a little white switch ( very small ) move this in the opposite direction of where it is and that should sort you out....hope this helps please vote thanks
Mar 24, 2010 | Electronics - Others
Windows was unable to format my flash disk
It seems that the card is bad. Try to format the card on a different machine to rule out your Windows formatter.
Aug 19, 2009 | Dell Inspiron 6400 Notebook
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My Transcend pendrive isn't being formatted
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pendrive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 13, 2009 | Transcend (589307) Media
Usb drive
flash drives do not have passwords, unless u have purchased password protected ones. pls checkup with your pc/cmera or mobile.
may be the flash is defective and all companies give replacement for this problem
Apr 19, 2008 | Electronics - Others
Mass Storage Device Defect
You might want to format it...If it doen't format as well then it has developed bad sectors..I dont want you to have a brain blast by telling you too much..but let me know whether its formatting or not..
Oct 27, 2007 | Computers & Internet
Transcend (589307) Media Logo
146 people viewed this question
Top Transcend Electronics - Others Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
