Split Air Conditioner Compressor Start Problem
A Dawlance Split Air Conditioner got its compressor blown that is replaced with china made. New compressor has been tested prior installation that shows 3 Ampere but, after installation and gas recharge it shows more than 30 Amp. and does not start.
    Problem Solver:
  • 6 Answers
You need to change it again.
rememper that I am not rich enghe to by the cheep
Posted on May 24, 2009
Any body tell me what is the problem with my 1.5 Dawlance split ac It gives perfect cooling in night and morning but in afternoon its compressor turn on and off every after 15 minutes. And due to this my...
when the heat ambient temps go up . the start capacitor gets hot to turn on fan and heat sensor for the compressor senses it and turns off . check the run/start cap first
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
Dawlance split air conditioner shows the eror in display f6
Check the condensor fan motor. If less RPM replace capacitor. still continues, replace f.motor.
Aug 25, 2012 | Dometic Heating & Cooling
Have a 4horsepower neo plasma split that keeps tripping out the fuse in the meter box.have had air con guy out and he says the 14 amp fuse is not sufficient for this air con even though it has run on it...
Please note your fuse wire must be 2 to 3 times of running amps. Suppose running amps is 6.5, the fuse wire must be minimum 15 and maximum 20 amps. Always choose the maximum.
Other chances for fuse blown;
And in your a/c, If your fuse tripped as soon as compressor starts, check compressor winding with ohms. In between 2 terminal it should be equal in 3 phase compressor. In single phase compressor, SR must be the total of other two.If any huge difference it means winding weak. If any ohms reads between any terminal and grounding it means compressor grounded for which you have to replace compressor.
Hope, it's helpful?
Jan 27, 2011 | LG LS090HE Split System Air Conditioner
Hi I am Armando and I have a LG AC Mo # LSN180CE and I start to hear a bearing rattle noice right after the compressor, seems to me like it. The evaporator is like 20' o 25' away inside of the room, the...
First of all confirm where the sound comes from whether from Indoor or out door. If from indoor, the blower bearing worn out/ blower wheel broken.
If from out door, fan blade broken (replace fan blade)/compressor internal sound(replace compressor)/compressor seating bush worn out.(replace new bushes).
Helpful.
Jan 21, 2011 | LG LSC121PMA Split System Air Conditioner
Fujitsu Air Conditioning split unit Model
Your compressor is seized up. shut down unit and let compressor cool down, it may start again but probably needs to be replaced.... sorry for the bad news,
Nov 10, 2009 | Fujitsu 24C1 Air Conditioner
Power to compressor but compressor will not start Unit is split system-2.5 ton, freon is good
i would check the capacitor( shiny little round or oval can) if bad get an exact replacement(mfd and voltage) if it is good i would try adding a boost capacitor(increases starting torque by 300%)
Jul 30, 2009 | Ruud Matching Split Air Conditioner
Heat controller mini-split air conditioner
Check each screw on your compressor to ground (compressor case). Should be very high resistance Then check the resistance across your teminals on the compressor to be sure it is not shorted. Then check the wiring to your capacitor (The big one). I ran across this just last week. The mechanic didnt have the capicator wired correctly. If it is brand new it will have a wiring schematic somewhere on it.
Dont leave the compressor on very long, but turn it on long enough to get a voltage reading across the terminals. I assume it should be 240 volts. If you have check all of this, they make a jump start gadget to start a stuck compressor. They sell it just about everywhere. Let me know how this comes out..
Sep 30, 2008 | Sanyo 24KS62R Cool Mini Split Air...
Split air conditioner
try to change the compressor proctection circuit, if ther is no problem with the compressor protection circuit most probably the compressor motor capacitor leakage problem r defective capacitor.
Sep 24, 2008 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
354 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
