Elekta Window Air Conditioner, Thermostat won't cut off.
I bought an Elekta Window AC (2.0 ton capacity). The AC cooling is excellent, however, the compressor does not cut-off automatically when the temperature is reached.
I have tried keeping the thermostat at highest cool, letting the room cool sufficiently, and then bringing the thermostat down. It still does not cut-off.
The Elekta technician who came and checked it says it's OK. You can let the AC keep running. I am afraid it will blow out the compressor.
Please advise
  • melroy_arrak May 24, 2009
    Thanks. How long should I wait before restarting the AC after I immerse the temp sensor into hot water?
Good morning, I'm using Elekta window A/C 1.5 ton and I'm using this for almost three years and now there is eritating sound while the A/C is running. Could you please advise what is the problem?
BR/Art
Posted on Sep 19, 2009
    Problem Solver:
  • 6 Answers
There is a temperature sensor try to imerge it into a hot water glass and the try again.
Posted on May 24, 2009
Mitsubish AC Model FDC 51 BA Q.1: what is capacity of this AC in tons? q.2: what is running current in amps?
Here is a YouTube video that helps you calculate tonnage of an AC.
The only way to know the running current if it's not on the AC info plate with all the other info is to measure it.
Calculating tonnage of your air conditioner
Oct 12, 2017 | Heating & Cooling
Q.1 : Mitsubishi AC model FDC-51BA how much capacity this AC has in tons Q.2 : What is running current in amps
Oct 12, 2017 | Mitsubishi Heating & Cooling
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
Need new one
Air conditioner equipment power in the U.S. is often described in terms of "tons of refrigeration." A "ton of refrigeration" is defined as the cooling power of one short ton (2000 pounds or 907 kilograms) of ice melting in a 24-hour period. This is equal to 12,000 BTU per hour, or 3517 watts.[13] Residential central air systems are usually from 1 to 5 tons (3 to 20 kilowatts (kW)) in capacity. To determine the correct size keep in mind that 12,000 BTU's equals 1-ton. Use the table below to determine the size AC that you need. Hope this helps. Area To Be Cooled (square feet) Capacity Needed (BTUs per hour) 100 to 150 5,000 150 to 250 6,000 250 to 300 7,000 300 to 350 8,000 350 to 400 9,000 400 to 450 10,000 450 to 550 12,000 550 to 700 14,000 700 to 1,000 18,000 1,000 to 1,200 21,000 1,200 to 1,400 23,000 1,400 to 1,500 24,000 1,500 to 2,000 30,000 2,000 to 2,500 34,000
Jan 08, 2010 | Intertherm P3RA-048K Air Conditioner
What is the cooling capacity of a 3 ton air conditioner
Hi, the cooling capacity for 3 tons of cooling is 36,000 B.T.U.'s, For every ton of cooling, you have 12,000 B.T.U's of cooling. I hope this is what you needed to know.
Good Luck,
Shastalaker7
Nov 04, 2009 | Carrier BCA101R Air Conditioner
Voltage Stabilizer for LG 1.5 ton window type ac
You should have around 120-125 volts at the outlet. If you have less than 110 volts at that one outlet, you may need to have your house wiring checked. Go ahead and call your local power company and have the power coming into your house checked at their transformer. They should do this at no charge to you.
Aug 02, 2009 | Heating & Cooling
Window unit not cooling properly, minimal cooling
SOUNDS LIKE ITS LOCKED OUT ON LOW LIMIT OVERLOAD CHARGE THE AC SHOULD START UP WHEN COMPRESSOR GETS AMPLE FREON
May 03, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Is the Model #25HBA360A300 a 5 ton unit?
36k-car-ms Key Features AC Type: Split System Additional Features: Ductless Cooling Capacity: 36000 BTU/hr Electrical Requirements Voltage: 220It is a 3 ton aprox 550 sq feet per ton is required
May 01, 2009 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
728 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
