Question about D-Link Xtreme N DIR-655 Wireless Router
DIR-300 router and broadband ISP connection,is NAT possible?
I have a broadband internet connection,the internet cable from ISP directly ends in my pc. I want to use a router(DIR-300)to configure my network.I intend to put the internet cable in the router input and an output cable in the switch.Will this affect my internet connection?
  • 3 Answers
With a cable broadband connection, the cable line comes into the cable modem. The cable modem does the work changing the cable signal to a network connection and sends an I.P. address to the computer. With some cable internet providers you can hook the network cable into the in port on a router, wireless or wired, then hook up computers to the router. At this point the router gets the IP from cable and uses it's own IP routing for your internal network. Some broadband providers control your access by the computers mac address which registers with the vendor. If this is the case then the easy way to make it work is to get a router which can clone a mac address so the vendor still sees the same mac address.
Posted on May 29, 2009
Direct access through LAN cable internet was working fine. whereas while connecting through DLink(Dir 600) pages were not loading correcly. I tried Netgear modem it was working fine. What is the probl
I would contact your ISP for help with this one. It should work but you would want to check the LAN and WAN settings to make sure they work on the network since there have been changes.
Aug 31, 2014 | D-Link Dlink Dir-600 Wireless Router...
I have just 2 computers currently connected to my Dell Power connect 2124...One is accessing the internet just fine but the other cannot acquire an ip.....I put new ends on the cable but stll no soultion
I assume you have connected your switch to any broadband router and then trying to access multiple systems at the sametime.
This is not possible if NAT (Network Address Translation) is not enabled on your broadband router.
Jan 08, 2011 | Dell PowerConnect 2124 Networking Switch
When I go through the installation on the install cd, it says error 322 and can't find the router. Its connected as described in the install instructions, what should i do? I'm going to use the DIR-300...
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Sep 27, 2009 | D-Link DIR-300 Wireless Router
PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Sep 06, 2009 | NetGear RangeMax WPN824 Router
Need nat type 2-PS3 Cable ISP digital phone modem wireless route
you can put your ps3 in a dmz zone. if still does not work its not your router. u can keep your ps3 in dmz and get your router to open ports. u can call your router company. If still does not work its not your router more than likely. It might be your modem. i have at&t and that was my issue. i went to dmz on modem and allowed it to pass through dmz zone and ip addresses to pass through. but make sure on your comp u have spyware or something. Your ps3 can not get virus.
Sep 06, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Hi I cant configure my router D-link DIR-300
Hi! I will be more than glad to assist u in this concern..Please dont use the setup cd or setup wizard. you can access the setup page of the router by typing at the url:192.168.0.1 then it will ask for the user name and password, by default the username is admin and the password, leave it blank.. here are the things u need to check before u setup u router.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 29, 2009 | D-Link DIR-300 Wireless Router
Slow Internet Connect
i have the same router. I recommend that you download a new driver of your lan card for your desktop pc, also if you have P2P and bittorrent applications, try to disable them first and see the difference, those programs slow down the your internet, because they hog your bandwidth and connects to multiple users.
Feb 01, 2009 | Compaq Armada M700 Notebook
Installation
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and if your ISP is dsl configure the router settings by setting your isp username and password
Step 7: test the Internet connection.
May 07, 2008 | Linksys Wireless-G Broadband Router
DIR-635 can't access the internet
I think you have wrong configuration of your router.
1. Some xDSL Internet Service Providers may assign a Fixed IP Address for your Broadband router. If you have been provided with this information, choose this option and enter the assigned IP Address, Subnet Mask, Gateway IP Address and DNS IP Address for your Broadband router.
2. If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must choose this option and enter the required information.
Nov 04, 2007 | Computers & Internet
D-Link Xtreme N  DIR-655 Wireless Router Logo
1,476 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
